Canon DR9050c Scanner
  • Chris Good
    • Jan 2013
    • 5
    [Misc] Canon DR9050c Scanner
    The document tray intermittently fails to lift on this scanner without an error code. The tray stays at the lowest position and the pick up rollers just spin. While this is happening, if you press upward on the flag that is between the pick up rollers, the document tray begins to lift and then it feeds the documents. We have tried uninstalling & reinstalling the drivers, no help.
  • zoraldinho
    teacher-guide-expert-guru
    • Mar 2008
    • 5015
    Re: Canon DR9050c Scanner
    Clean the sensors with a cotton-tipped swab or air blower.
    • teckat
      • 16083
      In service mode check if all sensors are indicating normal operation
      Feed Test
      Paper can be actually fed in this mode at the Dcon Check screen.
      The operation of sensors during feeding can be checked.
      If you need to check a feed operation only, it can be used “Count only mode” instead of the Feed Test.
      -Operation procedure
      1) Set the paper on the pickup tray.
      2) Select the [Feed Test].
      3) The pickup tray lifts and each roller rotates.
      4) The paper is fed at low speed and ejected onto the eject tray.
      5) When the [Feed Test] is selected again, the test stops.
      The operation of the sensor during feeding can be checked on the sensor confirmation
      screen.
      Sensors
      Perform the sensor operation check.
      When each sensor enters the detection state, the corresponding mark lights. Since there are many sensors, they are divided into groups. When the cursor is placed over the mark, balloon help is displayed.
      • Rachid.Akli
        • Oct 2011
        • 595
        Dear all,
        Document tray lift failure is mainly caused by the pick-up sensor position. The tray doesn't "go up" because this sensor always detects paper. The sensor position must be adjusted. Follow the attached PDF.
        Rachid.
        "Find a job you love and you’ll never have to work a day in your life." Nagy's father
        • Chris Good
          • Jan 2013
          • 5
          Thanx to all who have responded. Great ideas. Some have all ready been executed. What I need to go a little further is the service manual for this scanner. Does anyone have it?
          • teckat
            • 16083
            Tray May Not Lift
            Publication details a problem with the Document Tray not rising when prompted by the
            scanning application for the DR-6050C/ 7550C/ 9050C.
            There may be a problem with the Document Tray not lifting when prompted by the application.
            This inconsistent sensor detection may be caused by an insufficient extension of the Document Lever where it enters the slot of the Document Sensor.
            DR9050C TP11 327.pdf
            • acsolutions
              • Jun 2010
              • 519
              Hello, I have a jam problem on this model, It will feed fine for the first few sheet then it starts getting noisy(kind of a groaning) then jam. I removed the seperation roller then fed sheets with no problem,just intermittent multi feeding. I also replaced the seperation roller, still jams. I checked the seperation an feed assemblies for binding and worn belts, ok. The seperation is not adjustable and the area looks fine,the only thing I can think of is a worn motor (seperation motor), a very cheap pulse motor, it is $11.00 dollars so I ordered it. Not sure if the feed motor or seperation motor is bad,both assemblies look good. I noticed both feed and seperation motors are the same part number. any suggestions would be great! Thanks
              • teckat
                • 16083
                Check condition Separation Tension Spring
                -- Replaced the Exchange Roller Kit
                includes the Pickup Roller, Feed Roller, and Retard Roller.
                The Exchange Roller Kit is item #4009B001AA
                These parts are also available separately as orderable service parts:
                Pickup Roller-MG1-4268-000
                Feed Roller-MA2-6772-000
                Retard Roller-MG1-4269-000
                After replacing the Exchange Roller Kit, the Roller Counter on the imageFORMULA scanner must be reset. To reset the Roller Counter:
                1) Press the Menu Key on the control panel
                2) Press the Left Arrow Key twice until Roller Counter is displayed.
                3) Press the Enter Key once.
                4) Press the Left Arrow to select Reset and then Press Enter.
                5) The Roller Counter should now be at zero.
                check the pin for the Pulley Gear on the Separation Assembly. If the pin is damaged, replace the Separation Plate.
                Pick-Up Solenoid Check How many Total Sheets of Paper Used ( over a Million)
                Drive Belt. Adjust the Belt or replace if needed.
                • Rachid.Akli
                  • Oct 2011
                  • 595
                  Hello,
                  As you've proposed, replace the sep. stepping motor. Ref : MH7-1165-000.
                  Rachid.
                  • acsolutions
                    • Jun 2010
                    • 519
                    Hello, replaced the separation motor, but did not respond! I took a better look and found the upper guide plate was slightly bent causing it to bind on the registration roller, only when clam shell was closed. I removed the guide and it was not noisy during rotation and when feeding. It took me awhile to get it in proper form, then customer ran a few thousand sheets and it sounded good. if problem reoccurs will replace guide, it also looked like u turn guide may have also been effected. My guess is that someone shut the clam shell with an obstruction, causing the deformation. One thing I dont understand is when removing the separation roller there was no noise or jamming, just multiple feeding, this totally threw me in the wrong direction. Separation drive is totally separate from registration, transport and delivery sections. Thanks for the input guys
                    • Rachid.Akli
                      • Oct 2011
                      • 595
                      There is a very powerfull tool (service mode) for this model. You can use it to try any motor, sensor...
                      Rachid.
                      • acsolutions
                        • Jun 2010
                        • 519
                        would have been nice! Had to do it the hard way! Thanks
                        • rsjeff
                          Where can I find this service mode tool? The scanner I'm working on is not using the factory capture software.
                          Rachid.
                          • teckat
                            • 16083
                            SERVICE MODE
                            The service mode of this machine can be executed by installing the service mode software (service tool) located in the setup
                            disc bundled with this machine or supplied for servicing on the computer for servicing.
                            This service tool is an integrated tool that consists of a common EXE file and DLL files for each product.
                            The initial screen is shown below.
                            When a work button is selected on the initial screen, the corresponding screen is displayed and each service mode can be executed.
                            5) The initial screen is displayed.
                            6) If each service mode is executed, select [Select Scanner] and if the firmware is
                            registered, select [Firm Registration].
                            7) When [Select Scanner] is selected, the scanner selection screen is displayed.
                            Select the connected scanner.
                            8) The Main Menu screen is displayed.
                            To terminate the service mode, select
                            [x:Close] on each operation screen or select [End Application] from [File] on the toolbar.
                            Reference: Folder and files
                            • Canuck
                              Tech Specialist
                              • 1713
                              If the tray sits at the bottom and rollers turn,then the photo interrupt that detects proper tray feeding position is thinking tray is in upper position. Should be straight forward(actuator hanging up or something). Don't mess with sensor position if not necessary...thats why it has loktite on screw. Lots of good info here...should be able to figure it out. I have tons of these and older ones(9080,7580,etc). Pretty well all the same. Mine scan over 100k per month on each one. Awesome scanners
