Canon IR1023IF Download/stand by
  • donley
    • Jul 2025
    [Misc] Canon IR1023IF Download/stand by
    The copier is in download/stand by mode. Not using as a printer. Can't seem to get it out of this mode.
  • SCREWTAPE
    East Coast Imaging
    • 3396
    Re: Canon IR1023IF Download/stand by
    Join 3 years ago.
    3 post*
    1 post per year*
    Hum!
    Buy a manual.
    • teckat
      • 16083
      Here are some of your options
      1- get a manual
      2-replace DDR module FM2-4898-000 imageRUNNER / 1023iF on the IP pcb.
      3-unplug fax modem board and the LAN pcb from the IP pcb/ & power up to see if message pops up
      4-if installed>remove optional Universal Send USB stick and the optional PCL ROM/power up see if message pops up
      5-Last resort is flashing the imageRUNNER with the most current system software
      --if after flashing > message pops up u may need to replace Image Processor)
      if u have software---------
      With the unit powered on, short the two pins at JP141 on the Image Processor Board. This can be done with a screwdriver or an alligator clip. This will reset the machine so system software can be reflashed.
      • Cabo
        • Aug 2012
        • 41
        Install new firmware
        • Brian8506
          • 1664
          I've been able to reboot that by holding down numbers 1 and 9 while powering up. Hold til display says initiializing. If it works it may come back and then you'll need to update firmware. Worth a shot.
