ir5075 SEND box
  • Apach
    • 157
    ir5075 SEND box
    I need SEND key option on ir5075 on display screen. Someone can help me ?
    tnx
    There is no stupid question, just stupid answer
  • zoraldinho
    teacher-guide-expert-guru
    • Mar 2008
    • 5015
    Re: ir5075 SEND box
    If I understand correctly.You have trial send kit and you need a code.
    • Apach
      • 157
      Re: ir5075 SEND box
      On my display I have COPY/express copoy/e-mail/scan box. I need SEND box because I needed to posibility to scan lots of documents. I'm not sure if I need just code or do I need an extra card ?
      • teckat
        • 16083
        Re: ir5075 SEND box
        tnx
        -Sending documents through e-mail or I-fax is available only if the optional Universal Send Kit is activated. -Sending documents to a file server or an inbox is also available.
        -Sending documents via fax is available only if the optional Super G3 FAX Board is installed.
        -Sending documents to an inbox is also available.
        iR5075_spec_sheet.pdf READ
        Universal Send Kit
        - F1
        The Universal Send Kit enables you to send scanned documents via e-mail or I-fax, as well as send
        scanned data to be stored in file servers or User In boxes.
        To enable the Send function, the optional Universal Send Kit must be activated.
        You must register a license key to enable optional modes and functions.
        Each optional mode and function requires their own license key to be registered. There is no
        limit to the number of license keys that can be registered in the machine.
        Buyer Beware>Buy Online or
        Call Canon Dealer>PURCHASE PRODUCT Option>then REGISTER
        A license key can be obtained via a Web browser to access the license management system. Access
        the system by entering the following URL: Canon - lms -.
        For more information on obtaining the license key, see the License Access Number Certificate and the License Registration Booklet included with the various optional kits.
        1 Press [System Settings] [License Registration].
        2 Enter the license key using - (numeric keys) press [Start].
        • SCREWTAPE
          East Coast Imaging
          • 3396
          Re: ir5075 SEND box
          If you are still in need of this certification, I can help you obtain it. Universal Send Kit F1
