imagePRESS 1135/1125/1110 series--Countermeasure Against E009-0009 Error Messages
  • teckat
    • 16083
    [Error Code] imagePRESS 1135/1125/1110 series--Countermeasure Against E009-0009 Error Messages
    + instruction for replacement pdf
    One or more of the four gears in the fixing assembly may break causing E009-0009 errors.
    material of the gears is changed.
    Products Affected: //Serial Numbers Affected:
    imagePRESS 1135 ////ALL
    imagePRESS 1125 ////ALL
    imagePRESS 1110 ////ALL
    imagePRESS 1135+ ///LZQ00001 to LZQ00544
    imagePRESS 1125+ ///LZR00001 to LZR00518
    imagePRESS 1110+ ///LZS00001 to LZS00567
    E009-0009 Error Messages -TP12 430.pdf
    Instructions for Replacing the Engage_Disengage Gears .pdf
