Canon ir2016 E001 and E808 Problem
  • sweet.persona
    Engineer
    • Nov 2009
    • 414
    [Error Code] Canon ir2016 E001 and E808 Problem
    Hi to all
    i have problem on CANON IR2016 desplaying E001 and when i reset it machine desplaying another Error E808 !!
    i have replaced New Fixing Assy But no result !!
    can any One help me!!
    thank you in advance.
    A GREAT PLACE TO WORK - A GREAT PLACE TO GROW!
    DAMENE ABDEL AZIZ
    DJELFA
  • teckat
    • 16083
    Re: Canon ir2016 E001 and E808 Problem
    Originally posted by sweet.persona
    Hi to all
    E808
    error has been caused by one of the connectors for the fixing assembly not being plugged in when the unit is powered on.
    This probably happened after replacing the fixing assembly and not plugging in the connector or when trouble shooting on the machine for some other problem and leaving the connector unplugged.
    The connector is to the thermistors in the fixing assembly. In the general circuit diagram it is connector J255DH.
    The connector is a six pin connector with two yellow and two orange wires going into it.
    It is the top connector located above and to the right of the fixing assembly.
    It is behind a cover on the side of the machine.
    To clear the E808 code unplug the machine for about 10 minutes.
    If the thermistors are bad the code will appear but will not reset until the fixing film assembly is replaced. The part number for the fixing film assembly is FM2-3346-000.
