IRC 3220 Color Copier when printing colors do not align
  • sniper2g8
    • Jan 2013
    • 117
    Image RunnerC3220 Color Copier Problem when printing in color images come out blurry looks like colors do not align with each other please help
  • Luther
    • May 2006
    • 682
    Re: IRC 3220 Color Copier when printing colors do not align
    90% of the time its the itb unit (transfer belt assembly)
    • doktor
      • 214
      Send picture !
      • SCREWTAPE
        East Coast Imaging
        • 3396
        Call a professional. These kind of issues required a professional.
        • Fer
          • Nov 2009
          • 267
          Full ITB revision. New belt and cleaning blade. I replace the transfer rollers every 500k. After that u can see "waterdrops" on the prints.
          Give the drive roller a proper cleaning with a rubber cleaner until no longer any deposits come off. Don;t forget the bushings of the secondary transfer roller, toner makes the roller turn hard en causes the itb to bend, scratching the surface of the itb cover. U'll see streaks on the print.
          • canonbundy
            • Jun 2012
            • 607
            Clean Patch Read Sensors then perform Auto Grad adj.
            • SCREWTAPE
              East Coast Imaging
              • 3396
              Here are tips. Check this link http://www.copytechnet.com/forums/ca...n+canon+models.
              • teckat
                • 16083
                are u a tech
                purchase a manual to know your product/
                iR3200-3220 ITB Issues TP03.pdf
                READ
                need pics to identify issue//
                if in PAPER FEED(sub scan) or CROSS FEED(main scan) or Both
                • sniper2g8
                  • Jan 2013
                  • 117
                  i have change the cleaning blade and how do i change the ITB
                  • sniper2g8
                    • Jan 2013
                    • 117
                    After cleaning inside the main ITB unit the print colours was aligned but the print look horrible what should i do please help
                    • sniper2g8
                      • Jan 2013
                      • 117
                      after cleaning inside the main itb unit the print colours was aligned but the print look horrible what should i do please help
                      a big thanks to you all for giving me ideas
                      after changing the cleaning blade the quality is very good
                      once again thank you
                      • teckat
                        • 16083
                        Now purchase a SERVICE MANUAL----------------------------------
