IRC 3200 Color Copier ERROR when test 10 (pic)
  • hoangle188
    • Jan 2013
    • 10
    How to fix this problem??? Please help me....
  • Hitesh_honey
    • Aug 2011
    • 19
    Re: IRC 3200 Color Copier ERROR when test 10 (pic)
    Originally posted by hoangle188
    [ATTACH=CONFIG]19122[/ATTACH]
    pl service al 4 color unit and ipt belt clean, remove ipt belt and clean transfer charger, transmission rode also clear than fitted ipt belt.
    • Fer
      • Nov 2009
      • 267
      Check the gear driving the ITB, maybe it is chipped. Maybe the varistor is faulty, short it to see if the output changes. Replace the secondary transfer roller, just te be sure.
      Varistor is on the side of the ITB unit, between the 2 metal covers.
      • hoangle188
        • Jan 2013
        • 10
        Thank you very much! I did so you guide but not ok. I changed new ITB so not ok. Problem can where? please help me!....
        • hoangle188
          • Jan 2013
          • 10
          • SCREWTAPE
            East Coast Imaging
            • 3396
            ITB belt my friend.
            • SCREWTAPE
              East Coast Imaging
              • 3396
              Check the gear driving the ITB. Remember the drum images get transfer to the ITB belt. Try to isolate.
              • hoangle188
                • Jan 2013
                • 10
                Originally posted by SCREWTAPE
                ITB belt my friend.
                I have replaced both sets ITB other, I've tried all that you said but still getting this error. error or elsewhere??? Problem where??? help me please....
                • hoangle188
                  • Jan 2013
                  • 10
                  I have replaced new gear driving, both sets ITB other, I've tried all that you said but still getting this error. error or elsewhere??? Problem where??? help me please....
                  • sniper2g8
                    • Jan 2013
                    • 117
                    [ATTACH=CONFIG]19165[/ATTACH]
                    Try changing the drum unit of all the four colours i hope that will help
                    or you can take the drum of a working machine and try
                    sniper2g8
                    • hoangle188
                      • Jan 2013
                      • 10
                      sniper2g8
                      Thank you! I changed the drum unit of all the four colours but still getting this error. (
                      • Fer
                        • Nov 2009
                        • 267
                        Did someone clear the dcon? if so u need to input all the pprint values. Check the compartment in de front door, it;s behind a screw. If you're luck a factory p-print is there. Of not u can collect some values from labels on the machine. The lasers itself have labels on them.
                        Can u scan a pprint?
                        Did u try te reseat the connection between the dcon and mcon?
                        • hoangle188
                          • Jan 2013
                          • 10
                          Thank you! I have tried many ways but have not been. Haizzzz... not yet how to do???
                          • Fer
                            • Nov 2009
                            • 267
                            How to what?
                            PPrint = Get into service mode, select copier > Function > Misc-p > P-Print
                            Reseat the boards? Remove the complete rear cover. Remove the mcon controller cover, mcon is the metal box where the network cable plugs into. Remove the harddisk bracket, remove cables into the mcon pcb. Remove the screws holding the mcon box in place, remove the mcon box.
                            • teckat
                              • 16083
                              check your Patch Salt Sensor position ---see
                              Pattern Reader Unit
                              P PRINTS COPIER>ADJUST>LASER>PVE-OFST
                              Use it to enter an adjustment value for the laser beam position
                              Used to enter the adjusted value of the laser irradiation position.
                              Adjustment (Value after RAM clear: 0) or HDD replacement-------------------
                              Note-- This item is to enable input of the factory-adjusted value, and should not be
                              adjusted in the market.
                              L-ADJ-O
                              Automatically adjusts laser emission quantity.
                              This operation is used to compensate the time the laser lights during
                              minimum light quantity emission.
                              Each laser unit (Y/M/C/K) is adjusted in sequence.
