Hello,
I have purchased a Comswitch 7500 to have all devices on one phone line - Canon IR 2016i and Telephone with answering machine. I tried and tried to set this up without a communicator but was unsuccessful. I got the communicator in. The fax works fine if it is plugged directly to the phone line. However, when I add the communicator I get the error - TX Function was not completed. Also says result is NG No signal. Do you have any suggestions on the appropriate settings on the Canon IR 2016i so that is will run through the communicator.
Thanks, Trshi
Thanks, Trshi
