IR3025 Error E0024-0001
  • ldfrepairs
    • Oct 2012
    • 148
    Please advise on how to solve or clear error.
    drugstore-onlinecatalog.com
  • SCREWTAPE
    East Coast Imaging
    • 3396
    Re: IR3025 Error E0024-0001
    Check your developer.
    • ldfrepairs
      • Oct 2012
      • 148
      I did but cannot find anything abnormal. What is the test I am to run to verify working properly?
      • SCREWTAPE
        East Coast Imaging
        • 3396
        Check for bent pins on the connectors. Could be the the sensors. there are two. One on the developer and one on the sub hopper. Worst case, DC controller. Are you using OEM toner?
        • ldfrepairs
          • Oct 2012
          • 148
          Yes only OEM toner been used in copier.
          • teckat
            • 16083
            Toner gets in the developing assembly toner sensor (TS1) and may be shorting out the sensor. Blow out any toner in the sensor wiring and check to see if measure resolved the symptom.
            If the toner level sensor has an open-circuit, replace the toner sensor.
            Try a remove & re-attachment of the sensor sometimes also solves the symptom.
            When the symptom has occurred, make the following selections in service mode [COPIER > I/O > DC-CON] and check the setting for the bit1 of [P021]. If the setting is "1", re-attach the toner sensor.
            more-----------------------
            E024
            on an imageRUNNER 2230/2270/3025 series machine.
            One problem found has been the toner sensor scraper blade in the developer not making contact with the surface of the toner sensor. To check the toner sensor scraper blade first set up a work area.
            Lay out several sheets of 11 x17 paper on the work surface.
            Disassembling the developer is a messy job. Remove the upper cover of the developer and then rotate the developer in a counter clock wise direction. Basically the cylinder should rotate so the toner is scraped off of the cylinder by the developer blade.
            If it is rotated in the wrong direction a large amount of toner will adhere to the developer cylinder and makes a mess.
            The toner sensor is located on the on the outside of the developer and part of it goes through the wall of the developer unit.
            Next look at the inside surface of the developer where the toner sensor is mounted while rotating the developer cylinder in the correct direction. There is a mylar scraper sheet that needs to touch the inside surface of the developer wall. In the image below the inside surface of the developer wall is being touched by the mylar scraper blade. If the blade is damaged or broken off the toner will not be cleaned off of the sensor and give the error code E024. If the blade is the problem the developer will need to be replaced.
            The part number for the developer is FM2-0287-010.
            • tongee
              • Nov 2009
              • 50
              Use only genuine toner.
              • SCREWTAPE
                East Coast Imaging
                • 3396
                I once had a customer who had the same E-code. Did everything, replaced all parts related to this E24, from sensors, developers with brand new toner, Dc cont, wire harness. The problem went away, came back, went away, came back, It'd had turned out that they had a NP6245 before. They had a couple of boxes of this NP6245 toner. When they had ran out of toner, they would have to wait for another one. But most of the time when they ran out, it was over the weekend! We are closed! They were refilling the GPR16 toner bottles with the NP6245 toner. That's why at times the error went away and came back! Who says toner is all the same, its not!
                Good LUCK with that 24
                • Peter Sim
                  • Sep 2008
                  • 445
                  Mr teckat already show you everything.
                  Just follow the information.
                  If your TD sensor ok then you need to modify the mylar scraper sheet or replace.
                  Because the mylar scraper sheet need to touch on the surface of the TD sensor to count as one cycle,if the mylar scraper sheet are not touch the TD sensor surface for the cycle count ,the error code will appear.
                  • ldfrepairs
                    • Oct 2012
                    • 148
                    I tested the developing unit in another 3025 and no error showed. Tested all motors for the developing assembly all are working fine. Customer insisted that they did not use another type of toner in copier.
                    • teckat
                      • 16083
                      so when u replaced it back in issue printer > error returned
                      if so u need to
                      back track the connection from printer side to DCpcb
                      side
                      one thing to check is J312 & J302B connector on the DC Controller PCB.
                      • nochick
                        • Jan 2012
                        • 80
                        when Error E0024 comes
                        It's happen often when I change toner from one OEM toner to new OEM toner
                        or when my customer let the toner empty too long and when install toner it's just happen
                        I use this method since ir2230 /2270
                        - I check developer it will full of toner but machine say need toner
                        - Get toner out of develop & clean sensor
                        - just put it all back and install toner in service mode
                        that work for me over 20 machines
                        good luck
                        PS I really like the way teckat explain, it's very clearly
                        • ldfrepairs
                          • Oct 2012
                          • 148
                          Thanks Nocheck, your suggestion worked.
                          • Canon.Tech
                            • Mar 2009
                            • 335
                            I went to a machine with a history of E024, the machine also had the "prepare new toner message" (or the like) I was wondering if the customer kept opening & closing the toner door to try & clear the "add toner" message would this eventually throw the E024 error?
                            • ldfrepairs
                              • Oct 2012
                              • 148
                              I corrected issue by totally cleaning out the developing unit and replenish toner.
