E000009-00FF
  • Kloster
    • Jun 2025
    [Error Code] E000009-00FF
    iR 6800C EUR
    error code every 3hr.
    E000009-00FF what is it meaning?
    sorry about my English.
    thank you.
    • 16083
    Re: E000009-00FF
    Originally posted by Kloster
    E000009-00FF what is it ? thank you.
    • SCREWTAPE
      East Coast Imaging
      • 3396
      Re: E000009-00FF
      Unbelievable!
      • Kloster
        Re: E000009-00FF
        Canon
        iR 6800C EUR
        iR 6800C EUR
        • gensys
          • Jan 2011
          • 323
          Re: E000009-00FF
          Canon
          iR 6800C EUR
          iR 6800C EUR
          For iRC 6800 series (iR C6800C / iR C6800CN / iR 5800C / iR 5800CN)
          E009-00FF Error Code: Because of broken 24T gear in fixing drive unit
          Cause
          The possible causes of the detail code "00FF" are: the heating estrangement motor (M22), the external heating HP sensor (PS21), or the DC Controller PCB is
          faulty. In actual failure cases, when the external heating roller came in contact with or moved away from the fixing roller, the 24T gear hit against the stopper,
          causing a breakage of the 24T gear after long use.
          Field Remedy
          When this symptom occurs, inspect the 24T gear and replace it with a new one if it is broken. Simultaneously, visually inspect the 16/42T gear that drives the
          24T gear. If it is broken, replace it with a new one, too.
          Note: When replacing the 24T gear, it is necessary to remove the heating roller sensor flag that is installed in the same shaft as the 24T gear. As the sensor flag
          is secured by snap-in claws, it is possible that the claws might be broken if being released too much. If it is broken, replace it with a new one.
          Description
          E009-00FF: To be displayed when it is detected that the external heating roller remains in contact with the fixing roller.
          FU5-0178: 24T Gear
          FU5-0214: 16/24T Gear
          FC5-2358: External Heating Roller Sensor Flag
          The Road will be Mastered by >>> the Going...
            • 16083
            Re: E000009-00FF
            Canon
            iR 6800C EUR
            iR 6800C EUR
            imageRUNNER C5800 / C6800 / C5870U / C6870U
            E009-00FF
            Error :The copier displays an error code of E009, with a sub-code of 00FF. The 00FF sub-code may indicate the Outside Heating Roller remains in contact with the Fixing Roller.
            Check the operation of M22 in Service mode ( COPIER>FUNCTION>PART-CHK>MTR,) code 22 for the Outside Heating Roller Shift Motor.
            If the motor does not activate, confirm the continuity of the wiring from the DC Controller at J1118. In this instance it was discovered to be a poor connection at J1118 on the DC Controller.
            If the wiring checks good, suspect the motor first, then the DC Controller.
            Outside Heating Roller Shift Motor - FK2-0153-000
            DC Controller - FM2-0867-030 - IRC5800 / 6800
            FM2-6056-000 - IRC5870U / 6870U
            • Kloster
              Re: E000009-00FF
              E009-00FF
              Thank you for your informations i has replace Heating unit all error sloved.
                • 16083
                Re: E000009-00FF
