IR 3035 slow faxing
  • tsb13
    • Mar 2009
    • 28
    IR 3035 slow faxing
    I have a customer that uses their ir3035 for faxing and their complaint is slow sending faxes as well as sending more then one fax before the first is done sending the second and third fax times out or takes 15 to 20 min. to complete. They said they have had the line checked by Knology, tests o:k. any ideas? Just started as far as i can tell a couple weeks ago. They have had the machine for a couple years with no problems.
    Thanks in advance.
    TSB13
  • Herrmann
    • Jan 2006
    • 792
    Re: IR 3035 slow faxing
    Did they change their connection line to "Voice over IP"?
    If sometimes you feel a little useless, offended and depressed always remember that you were once the fastest and most victorious sperm of hundreds of millions!
      • 16083
      T.38 - voip-info.org
      turn off the -Check Dial Tone Before Sending- feature.
      Turning off this feature causes no problems and will not affect the sending or receiving of faxes.
      press ADDITIONAL FUNCTIONS
      select COMMUNICATIONS SETTINGS
      under FAX SETTINGS select TX SETTINGS
      select CHECK DIAL TONE BEFORE SENDING
      set this value to OFF
      press OK
