error code e000021-0003
  • 4raddoo
    • Oct 2011
    • 30
    [Error Code] error code e000021-0003
    please i have canon machine ir3100cn and this error code e000021-0003 has being appearing on it. can anyone help with this error code.
    thank you.
    and i want to thank all those who has being helping me to find solution to my problems.
  • zoraldinho
    teacher-guide-expert-guru
    • Mar 2008
    • 5015
    Re: error code e000021-0003
    Start by the book:
    The sensor does not detect the flag when the developing rotary stops at development point:
    Rotate the developing rotary in a counterclockwise direction by hand to see whether it rotates smoothly
    Inspect developers,ITB condition,developer motor,connectors......
    • vamoursly
      • Sep 2011
      • 273
      Just took a look in the SM;
      14.3.10.12 E021-0003 Error Code: Occurs during copy, not upon FAX reception but output becomes yellow
      0005-7415
      iR C3100 / iR C3100N
      [ Case in the field ]
      Description
      E021-0003 can be displayed when the rotary HP sensor cannot detect the developing position detecting sensor flag although the developing rotary stops at
      development point.
      Cause
      In the field, this symptom occurred because of breakage of the developing position detecting sensor flag that is located on the rear rotary flange.
      Field Remedy
      Visually inspect the rear rotary flange to see whether or not the developing position detecting sensor flag is broken.
      Rear Rotary Flange: FC5-0299
