CANON iR20161 tOUCH SCREEN CALIBRATION
  • trshi
    • Jan 2013
    • 11
    Hello,
    Can someone please tell me how to calibrate the touch screen on the Canon Ir2016i?
    Thanks, Trena
  • teckat
    • 16083
    Re: CANON iR20161 tOUCH SCREEN CALIBRATION
    Originally posted by trshi
    Hello,
    Thanks, Trena
    procedure is as follows:
    1) Enter Service Mode (Additional Functions Key, the "2" Key, the "8" Key, and the Additional Functions Key)
    2) Press the Left Arrow Icon until you reach "#Test Mode" on the Display
    3) Press "OK"
    4) Press the number "6" Key on the Number Key Pad
    5) Press the number "7" Key on the Number Key Pad (The word "Factory" should be on the display along with Icons 01, 02, and 03)
    6) Press "01" Icon (The "01" Icon should be highlighted)
    7) Press "OK" ( The words "Touch Panel XY Adjust" should appear on the display)
    8) Press "Touch Panel XY Adjust" (The "Touch Panel XY Adjust" Icon should be highlighted)
    9) Press "OK" (A small plus sign (+) will appear in the upper left corner of the display)
    10) Touch the center of the "+" sign. Note: Use the Touch Pen to prevent damage to the display surface (Another "+" sign will appear)
    11) Touch each "+" sign that appears on the display until the "Factory " screen returns
    12) Press the "Reset" Key twice
    13) Power the machine Off/On
    • trshi
      • Jan 2013
      • 11
      I can get the the third (+) on the upper right hand of the screen but it will not let me go any farther. Any suggestions? I will keep trying though. Thanks!
      3) Press "OK"
      • captanil
        • Jul 2022
        • 1
        this was very helpful.
        but i can't click the OK button as lower 1cm of screen is not responding to the touch.
        i tried all clear as well and reset the machine but still same stuck as OK.
        pls advice a workaround
        3) Press "OK"
