Hi everyone,
Yesterday i got an error message on a Canon iR 7200 - E240-002. If you copy small series 20 to 50 copies, everything works well, but if you start copying larger series etc. 400 copies, the machine makes about 100 copies, and then stops printing. there is no error message on the display yet, it still says printig... and it stays like that for about 10 minutes. After that error message appearson the screen, and the machine restarts all by itsef. When it turns back on, I see that the paper stops in the same place every time. It stops just in front of the registration roller.In service manual it said : replace dc controller or replace main board. Is there any other solution to this problem?
Thanks in advance.
Thanks in advance.
