Jam Code on Imagepress C6000S
  • seniortech
    • Dec 2007
    • 180
    I am getting jam code 0CF1 09 (location) on an Imagepress C6000S. I cannot find this code in my service manual, I did not think an Imagepress even had a Jam location 09.
    Can anyone help me with some info.
  • zoraldinho
    teacher-guide-expert-guru
    • Mar 2008
    • 5013
    Re: Jam Code on Imagepress C6000S
    This is remark i believe:
    With the 2-sided waiting position full, a new paper is fed.
    Jam occurred and due to the accessory-related cause, and the delivery failed
    • seniortech
      • Dec 2007
      • 180
      Thanks Zoraldinho, where did you find this info, I have looked everywhere
      • seniortech
        • Dec 2007
        • 180
        Still getting this code, It's now becoming a real pain, It appears at random throughout the day, sometimes there is a gap of several hours between jams. it is happening on all types and weight of media. It happens from both POD deck and internal trays on single and double sided, face up and down I have 'cheated' the system so that heavier media does not use the secondary fuser and the fault still occurs. Have looked on SIMS and checked all relevant documentation, all I can gather from the service manual is that it is a sequence jam, but there is just a blank space in the manual against this jam code. however when the jam occurs paper is spread throughout the machine and tracking down exactly what component, sensor or process is causing the fault is impossible.
        • zoraldinho
          • Mar 2008
          • 5013
          You must tested with the one particular print to find jam issue but it's almost impossible i know.
          • teckat
            • 16083
            L: location of jam
            00
            host machine
            01
            feeder
            02
            finisher / insertion unit / punch unit / booklet trimmer / two-knife booklet trimmer
            11
            POD deck
            12
            Secondary POD deck
            31
            professional puncher / professional puncher integration unit
            51
            stacker (Primary)
            52
            stacker (Secondary)
            61
            perfect binder
            CODE: jam code
            P: source of paper
            01
            right deck
            02
            left deck
            03
            not used
            04
            not used
            07
            side paper deck
            08
            manual feeder tray
            09
            duplexing assembly
            0A
            inserter for finisher (upper)
            0B
            inserter for finisher (lower)
            10
            POD upper deck
            11
            POD middle deck
            12
            POD lower deck
            13
            Secondary POD upper deck
            14
            Secondary POD middle deck
            15
            Secondary POD lower deck
            60
            inserter for perfect binder (upper)
            61
            inserter for perfect binder (lower)
            0C xx Sequence jam
            0CF1
            L= Location=00=host machine
            P= Source of Paper/Pickup position=09=duplexing assembly ????
            what does it look like/say on the next Detail screen ???
            see example-----------
            check inside the duplex area ?????????????
            Two things to try------------for 0CFx Jam codes
            1-try removing & re-seating the connectors on the dc controller and video cables-
            2-Perform a hard drive de-frag by holding down the 1&9 keys while powering on the machine.
            let this finish/ may take 20min.
            imagePRESS C7000VP / C6000VP / C6000
            Jam Code List
            1. Engine
            2. POD
            3. Stacker
            4. Paper Deck
            5. Finisher
            - Saddle Assembly
            - Inserter Assembly
            - Trimmer Assembly
            6. ADF
            C7000VP-C6000VP-C6000 Jam Codes.pdf
