E020-03d0
  • V-P
    • Apr 2011
    • 679
    E020-03d0
    Customer often getts this error for the cyan unit.
    Strange thing is that PG-10 shows perfect coverage of cyan (it shows perfect all colors).
    I did clean the calibration sensors.
    Am I missing smth ?
  • zoraldinho
    teacher-guide-expert-guru
    • Mar 2008
    • 5017
    Re: E020-03d0
    Model??
    • V-P
      • Apr 2011
      • 679
      Re: E020-03d0
      hahaha - CLC5151
      • zoraldinho
        • Mar 2008
        • 5017
        Re: E020-03d0
        Did you have problems with previous cyan drum?
        • V-P
          • Apr 2011
          • 679
          Re: E020-03d0
          Ok - called customer to ask this intriguing question.
          He said yes.
          He also said that sometimes they have to restart the machine "when the machine goes crazy and there is no cyan output"
          After restart it comes back ok.
          • Rachid.Akli
            • Oct 2011
            • 595
            Re: E020-03d0
            He said yes.
            Hello,
            This is what the doc says:
            03D0: No toner is supplied from the toner cartridge to the developer. TCRG motor fails to run. An empty cartridge is being used. The toner supply port of the drum unit is damaged. Broken or disconnected wire in the ATR sensor.
            1- Replace the toner cartridge (thetoner feed screw may block during toner supply)
            2- Replace the cyan toner supply motor M22.
            Rachid
            "Find a job you love and you’ll never have to work a day in your life." Nagy's father
            • V-P
              • Apr 2011
              • 679
              Re: E020-03d0
              Hi Rachid !
              This is not the case here. As I said PG-10 looks great.
              And the error happens randomly...
              • Rachid.Akli
                • Oct 2011
                • 595
                Re: E020-03d0
                Hi Rachid !
                "PG-10 looking great" doesn't mean that the toner/developer ratio equals the reference value. when Toner/Developer ratio is lower than the reference value, the machine continues printing and at the same time it asks for toner supply. If the ratio is still lower, it deduces that the toner bottle is empty or may display the ERROR code E020.
                As a first step, i advise you to call your custmer to replace the toner cartridge.
                Rachid.
                • Fer
                  • Nov 2009
                  • 267
                  Re: E020-03d0
                  Replace toner AND drum together. This is the best way to get rid if this problem for good.
                  • V-P
                    • Apr 2011
                    • 679
                    Re: E020-03d0
                    Rachid.
                    This customer is a print shop Rachid. They print 500-1500 heavy coverage prints / day. Trust me if that was the case they would know it in 10 min.
                    The customer had already replaced the cyan toner (they have a lot of experience with these machines)
                    • zoraldinho
                      • Mar 2008
                      • 5017
                      Re: E020-03d0
                      He said yes.
                      When the machine have "no cyan output" issue inspect values in service mode.Also check M22 signal and connectors,cyan Toner feedscrew and
                      check the concentration of toner inside the developing assembly.
                      Take a look inside the machine and inspect Developer Drum Drive parts.
                      • Gamut
                        • Jul 2008
                        • 216
                        Re: E020-03d0
                        Only time I've had this it was the TD sensor = replaced drum.
                        Had similar error on irc3220 was the calibration sensor shield not being opened fully, only affected cyan though. Previous techs had been replacing drums that would last a few K then bang error.
                        • V-P
                          • Apr 2011
                          • 679
                          Re: E020-03d0
                          Take a look inside the machine and inspect Developer Drum Drive parts.[/QUOTE]
                          lol - I like the way you think
                          I have planned a visit on Monday to check the Dev. rotation-ability.
