Canon Ir5570 - Error E000100-0001
  • prntrfxr
    • 1622
    CANON IR5570 - Have ERROR E000100-0001 - reset error and I get the same error.
    update: broken thermistor cable from fuser to dc controller. replaced it, but still have problem. shorted controller board?
    Last edited by prntrfxr; 04-17-2008, 02:04 PM. Reason: update in troubleshooting - problem not resolved
  • kwazimoto
    • Jan 2007
    • 199
    A E-100-001 is a laser code or dc controller problem not one with the fuser.... before you start replacing parts check to make sure the shutter is ok first....SOunds like to me we need to know what the error code really IS....
    • kwazimoto
      • Jan 2007
      • 199
      if it is a e-001 CODE DID YOU RESET IT IN SERVICE MODE!!!!!
      • prntrfxr
        • 1622
        yes I did reset from service mode. checking other things you've suggested now.
        • prntrfxr
          • 1622
          replaced dc controller - cleared error code. now I have registration problem - performed adjustment, think may be problem with reg. clutch. got one on order. thanks for the help
          • Irish
            • 110
            E100 and reg issues??? dont rule out laser ..
            • setupexe
              Hey Hi i try to find how reset my IR C2880i may be is the same steps likeyou canon IR 5570 any idea how? someone tollme * 4 atri but nothing my error is E000045-0000
              someone tell me thats the fuser need reset
              i have a papaer jam
              and then error e000045-0000
              thankx
              • prntrfxr
                • 1622
                • prntrfxr
                  • 1622
                  machine working good:
                  replaced main fuser cable - very FUN repair.
                  cleared error - had unrelated registration problem
                  diagnosed bad reg. clutch and worn reg. roller
                  replaced registration unit
                  works really good.
