If the printer has the latest firmware installed (Ver. 1.25 or higher - iPF8300 Series), you only need to do the following:
1. Check if the Status Print or Print INF files indicate which print head experienced the error and replace it.
2. If the specific print head failure cannot be determined, replace both print heads.
NOTE:
With the latest firmware installed, it is no longer necessary to replace the Carriage Relay PCB. Make sure to apply the latest firmware updates to all of the printers. September 25, 2012
iPF 8300 / 8300S
2F48Error Code In one case both print heads and the Carriage Relay PCB were replaced to resolve the error code. PROCEDURE:
1. Turn off the printer and remove the current print heads (DO NOT INSTALL THE NEW PRINT HEADS AS YET) 2. Replace the Carriage Relay PCB (QM3-3121-000).
3. Power the printer back on in User Mode without the print heads, then install them when the printer requests.
4. Follow all printer instructions to continue booting.
Hi, I ust changed Carriage Relay PCB, Head Management Sensor and Multisensor due to 2f48 on my IPF8300,
now I have 2f25.
Any Idea what to do?
