Ir2025
  • copicatt
    • Nov 2008
    • 366
    Ir2025
    Is there any update to remedy ads double feeding? Replaced sep pad twice. Couple weeks later, starts again. Is there something else I need to change or check? Thanks!
  • SCREWTAPE
    East Coast Imaging
    • 3396
    Re: Ir2025
    If you look at
    FIGURE P33PAPER FEEDER ASSEMBLY
    #19
    FF3-4631-000 1 REVERSE GUIDE UNIT
    Try replacing this all part.
    I don't think it comes with sep pad.
    You can try this as well.
    FIGURE P31
    OPEN/CLOSE PANEL ASSEMBLY
    FG3-4043-000 1 PICK-UP ROLLER ASSEMBLY
    S.T
    • teckat
      • 16083
      Re: Ir2025
      Pickup Unit and Stopper
      The pickup unit consists of a pickup roller and separation roller. When the print start key is pressed or an document pickup signal is input, the pickup motor (M2) turns in the reverse direction to lower the pickup unit, turning the pickup roller and separation roller to feed the document. The stopper rises in conjunction with the pickup unit.
      When the document is picked up, the separation pad and separation plate prevent multiple sheets from being fed together.
      When the document is looped at the registration roller, the pickup motor turns in the forward direction to raise the pickup unit, feeding the document with the registration roller. At this time, the separation roller drive shaft driven via the spring one-way clutch stops at the upper limit of the pickup unit and the friction against the document forces the separation roller to rotate with the aid of the one-way clutch.
      U need to remove >clean & or replace both Pickup Roller and Separation
      Roller
      UNIT
      FG3-4044-000 SEPARATION ROLLER UNIT
      FC3-1525-000 1 ROLLER, PICK-UP
      DADF P1 -feed-sep unit.pdf
      • Rachid.Akli
        • Oct 2011
        • 595
        Re: Ir2025
        The pickup roller axis turns once. This is ensured by the pickup solenoid SL3 which may have a sticking plate issue (the usual storry of dampers) resulting on a multiple rotation of the pickup rollers. So, have a look on the solenoid damper.
        Rachid.
        "Find a job you love and you’ll never have to work a day in your life." Nagy's father
        • copicatt
          • Nov 2008
          • 366
          Re: Ir2025
          Rachid.
          The pickup roller is just cycling once. The paper is actually double feeding together (at the same time). Wandering if maybe the top door isn't closing good. (Thus reducing the pressure)
          Thanks for the info.
          • SCREWTAPE
            East Coast Imaging
            • 3396
            Re: Ir2025
            There's definitely a slight gap between pick-up roller assembly & the sep pad if its multi feeding. Add a little pressure with your hand on the adf cover as it feeding. I doubt that's your problem. Have you tried changing the spring under the sep pad. How many copies this machine has?
