Canon IR5000 E240 etc
  • CopierTechofOmens
    Agitating Artificer
    • 268
    [Error Code] Canon IR5000 E240 etc
    Picked up a Canon serviced by another company. I was told it's been sitting.
    Symptoms:
    • Light area down center of page (Transfer cleaner drive shaft out of position cleaner stuck in center)
    • All service related counters reset to 0.(Not sure which PWB stores these) Copy Counters are fine ~600K.
    • When copying, machine starts process, paper almost reaches registration assy. After almost a minute machine resets and shows a Jam. E240 declared.
      • Registration pressure roller has flat spot.
      • After reading about this error on other Canons my guess is the Registration clutch is overloaded or shorting the DC controller PWB out?
    Anyone ever have a similar issue?
    sigpic
  • zoraldinho
    teacher-guide-expert-guru
    • Mar 2008
    • 5018
    Re: Canon IR5000 E240 etc
    -Reconnect(re-seat) all controller connectors and memory. Copier in your case can have coating of oxide or rust on connectors.
    -Clear dc and main controller.(p-print)
    • CopierTechofOmens
      Agitating Artificer
      • 268
      Solution was to replace the registration assy. I also reconnected the counter pwb. Afterwards all counts incremented accurately and all jamming was resolved.
      sigpic
      • zoraldinho
        • Mar 2008
        • 5018
