CANON GP335 gives me black copies
  • Guest
    CANON GP335 (1).jpgCANON GP335 gives me black copies (not solid black) but when i set brightness 'lighter' i can see the scanned image but all in black.
    scanner seems to work thats why i get image but whole page and image are under black 'cover' not solid.
    any idea pls?
  • canonbundy
    • Jun 2012
    • 607
    Re: CANON GP335 gives me black copies
    Probably the Scan Lamp on its way out.
    • Canon.Tech
      • Mar 2009
      • 335
      No it won't be the scan lamp as this would throw an error code.
      When was the last service & drum change?
      Most likely you need a new drum unit, the cleaning blade fails & creates a black/dark image on prints & copies
      • zoraldinho
        teacher-guide-expert-guru
        • Mar 2008
        • 5013
        Post a sample please.
        • Guest
          • Canon.Tech
            • Mar 2009
            • 335
            Try doing an internal print, a history print for example if that's the same you can rule out the scanner.
            If you have another black drum unit, even a worn out one, try that, it looks like from your sample theres a bad drum earth
            • Guest
              how to make internal test prints since the menu doesn't give me that option. any key combinations or something?
              • zoraldinho
                • Mar 2008
                • 5013
                First make Initial Checks.With no results start with drum.
                Making Initial Checks.pdf
                • Guest
                  i wanna say a huge thnx 2 all of u guys 4 ur support.2morrow i will try all u said and hope 4 my own good 2 get some result.
                  • Guest
                    i wanna say thanx to Canon.Tech for his instructions of how to get in service mode
                    and later to zoraldinho for the initial settings pdf file.
                    finally 2day i made some adjustments for density, specifically:
                    According the service manual:
                    Execute the following underCOPIER>FUNCTION>DENS
                    in service mode:
                    1. WHITE-ME
                    2. PD-DENS
                    3. PD-ME
                    4. DZ-DENS
                    5. DZ-ME
                    impressively improved result
                    and then:
                    COPIER>ADJUST>DENS>DENS-ADJ
                    internal prints were perfect so the problem must be to scanner section ccd or icboard
                    im not sure if the problem is hardware or software and if it has gone bcause of the settings or is still 'there' bcause of hardware, possibly is still there but anyway it works.
                    all of u know better than me.... and let me know what u think
