CLC4040 fiery
  • mido
    • Nov 2011
    • 177
    CLC4040 fiery
    Hi all,
    Please I want to adjust the fiery of clc4040 by (Kodak color separation guide and gray scale)
    * Can you tell me the way or steps about this adjustment?
    * What is the difference between the IR series and CLC series? rather than the fiery.
    thanks
  • Fer
    • Nov 2009
    • 267
    Re: CLC4040 fiery
    CLC4040 = European marketing for a IRC4080 with a external rip, Fiery H1 or G300. Rather then the Fiery, a CLC4040 will have no internal printing KIT and no send kit by default.
    Step 1. Calibrate the machine with the auto gradation adjustment in the adjustment/cleaning menu. Choose Full Gradation, print and scan the calibration pages, 3 pages in total.
    Step 2. Go to the "printer" tab en select calibrate, machine will print a calibration page
    Step 3. Put the kodak chart in de top left corner of the scanner glass, put the calibration page on top
    Step 4. Scan page, this the next step in the calibration process, you will be asked to do so.
    • teckat
      • 16083
      Re: CLC4040 fiery
      Calibration Procedure
      1. Clean/Adj optics. Clean/inspect optics and white plate/roller. Perform CCD Adj.
      Some older machines will be CCD Adj (without paper) and newer machines will be DF-WLVL 1-4 with good quality white paper.
      2. Perform Full Auto Gradation. Now that the optics can properly read the data calibrate the copier. Perform this adjustment on the media being used to print onto. Bright white (98-100) 24lb-28lb is recommended for plain paper over using 20lb bond for more accurate color reproduction. If the customer is using card stocks perform adjustment on this as well. Generally 32lb-60lb cover is Heavy 1 and 61lb-80 cover is Heavy 2.
      3. Calibrate the Fiery RIP. Enter calibration mode on copier through Printer, Settings, Functions, calibration, enter Fiery.1 for the password and press OK. If you do not have a densitometer choose the Standard Color Cal Measurement page method under set-up. Use a clean Grey Scale positioned in the top center of the letter size portrait area of the platen glass. Press Calibrate and Yes to print the Measurement Page. Place printed page over the Grey Scale and press Yes and then done to measure. After successful measurement press Yes to overwrite and to it affecting all users.
      4. Print out a Test Page and Configuration Page. Under Printer, Print Pages, Test Page the Configuration. After verifying print quality place these with the COMPLETED Service Log attached to the machine.
      5. Verify Customer Knowledge on Calibration Procedure. Ensure that the customer is aware of Steps 2 and 3 for increased quality/reliability and service time.
