DR-7090C Scanner password
  • spanner
    • Jul 2025
    [Error Code] DR-7090C Scanner password
    Hi Does anyone know the password for the 7090tool to access the scanners service Mode?
    Error code jam P148 any ideas?
    Service manual download ?
    thanks
  • zoraldinho
    teacher-guide-expert-guru
    • Mar 2008
    • 5007
    Re: DR-7090C Scanner password
    P148 jam = Initial stagnation (clean or replace pick up,feed and separation rollers)
    password = market
    • teckat
      • 16083
      thanks
      DR 7090C
      P148 Jam
      If the P148 Jam occurs, clean the optical sensors in the paper path and perform the SENS-INT Adjustment with the Service Tool. To perform the SENS-INT Adjustment:
      1) Launch the 7090Tool.exe located on the Driver CD in the Tools folder.
      2) When the password prompt appears type in the password "market".
      3) When the Service Tool appears, click on the Feeder button
      4) Click on the tab labeled Function.
      5) Click the Start button, next to SENS-INT, to start the adjustment.
      • teckat
        • 16083
        thanks
        Another point noted by Canon on P148
        Jam code P148.
        Tech ran service tool and found that PCB4 did not change logic states when tested. Tech swapped PCB2 with PCB4 and problem followed the sensor. Tech installed new sensor, but still got the P148.
        In this case, the tech looked in the paper path under PCB2 and found a small scrap of paper at the sensor location. Removed paper scrap and resolved the issue.
        • teckat
          • 16083
          More P148 INFO
          Category / Model :
          Document Management / DADF-M1, DADF-S1, DADF-T1, DR-7080C, DR7090C
          Classification :
          Error Codes
          Problem :
          Error P148 DR Scanners or Jam Code 0094 for DADF units
          Sub-Assembly :
          Post-separation Sensor (PI7 / PCB2), Read Sensor PCB (PI8 / PCB3) or Delivery Reversing Sensor PCB (PI9 / PCB4) reference is dependent on model
          Cause :
          Faulty sensor or missing light guide or reflective prism
          Solution :
          Replace sensor (FM2-1022-000), Light Guide/Sensor Holder (FC5-3131-000), or Prism (part of Upper Delivery Guide (FL2-5987-000)).
          Remark :
          There are 3 sensors in the system
          Date Created :
          10/12/2009
          Author :
          Anonymous
          • zoraldinho
            • Mar 2008
            • 5007
            Hi Teckat.
            For 7080 and 7090 is not "market" i think.
            • zoraldinho
              • Mar 2008
              • 5007
              Originally posted by zoraldinho
              Hi Teckat.
              Yes,i check.It's market. Sorry.
              • spanner
                password = market
                Thanks zoraldinho will get back and give it a try.
                • spanner
                  Originally posted by teckat
                  More P148 INFO
                  Category / Model :
                  Classification :
                  Error Codes
                  Problem :
                  Sub-Assembly :
                  Cause :
                  Solution :
                  Remark :
                  Date Created :
                  10/12/2009
                  Author :
                  Anonymous
                  Thanks Teckat for your 3 very detailed posts, should give me a fighting chance to fix it...................cheers spanner
