no network printing with Canon imageRunner 2525
  • TheEPOCH
    Hello together,
    can someone help me to find a solution for following problem.
    When i tried to print over the network interface the imageRunner 2525 outputs a single beep but I did not get any printed page.
    • iR 2525 was preconfigured with a static ip and was functional in this configuration
    • The iR 2525 was used in a network but only on one workstation use print and scan function (the device is mostly used as copier)
    • Now the workstation had get an update (fresh install) with Windows 7
    • I installed the latest driver and within the setup routine the iR is correctly found in the network. Setup finish without any error.
    • I can configure the settings and properties in the windows device manager, i don't get any error.
    • When i try to print i get NO error message, nothing in Windows, nothing in the printer menu, printer beeps (so there have to be a connection between pc and device) the only thing is that the printer does not generate any page.
    Had somebody an idea or a solution for me?
    I'm sorry for my bumby english! Best regards from germany!
    Fabian
  • Rachid.Akli
    • Oct 2011
    • 595
    Re: no network printing with Canon imageRunner 2525
    Originally posted by TheEPOCH
    Hello together,
    Fabian
    Hello,
    There are two things that you have not noticed in your thread: The Win7 version ( 32bits or 64bits) and the driver type UFRII. So, take care to instal the right one.
    Rachid.
    "Find a job you love and you’ll never have to work a day in your life." Nagy's father
      • 16083
      http://www.usa.canon.com/cusa/support/office/b_w_imagerunner_copiers/b_w_imagerunner_copiers/imagerunner_2525#DriversAndSoftware
      imageRUNNER 2525
      imageRUNNER 2525 / 2530 / 2535 / 2535i / 2545 / 2545i
      • Fer
        • Nov 2009
        • 267
        Originally posted by Rachid.Akli
        Hello,
        Rachid.
        This guy has the right solution!
        Most low-end Canon MFP's do not have a PCL printing kit installed. This means the print jobs submittted with a PCL driver will not print. U need to download and install the UFR 2 driver.
        Canon UFR II/ UFRII LT Printer Driver v20.85
        This link leads to the German UFR 2 driver for Windows 7. They are both x86 and x64 these days.
          • 16083
          Canon driver link posted already, thanks
          • TheEPOCH
            Hello together,
            indeed this was my mistake! Thank you all for your help!
