I am getting code 010c when printing pages from tray 1, but when I try tray 3 regular (long way) it feeds fine. It always jams inside the fixing unit. Any ideas would be great?
IR8500 jamming code 010c
Re: IR8500 jamming code 010c
Things to check:
Internal delivery Roller
sensor Flag
Jam codes 010C are sometimes due to a worn sensor flag part number FB4-2303-000 or a worn internal delivery roller FB5-6833-000.
Also,
- Lever Deflector FB4-2299-000, may be out of position or linkage to deflector may get stuck and need to be cleaned and lubed.
- Clean and adjust SL3 on transport. Solenoid is located under fuser unit. Screws for SL3 may also come loose.
- Clean and adjust reversal solenoid, SL11.
