Error code E246-0005 on ir3300i
  • lordbison
    • 12
    Hi eveyone.
    I have this problem on a ir3300i (E246-0005). I have already change the boot flas dimm and nothing happened. Also change the ram memory and still the same. I clean all the contacts with electronic spray and specially the counter board and still the same. I hope anyone can help me.
    Good day.
  • ninja copy
    Copier repair
    • Mar 2008
    • 24
    santiscnyl@gmail.com
    • nivssluck
      • May 2008
      • 228
      ir3300i (E246-0005)
      in ir machine i thinke E246 is counter and serial error...your counter and serial did not match...
      • tuli
        please change the serial board and pcb counter
        try it.it wil solve that issue
        tuli
        • phollawat Chaimoonchuen
          • Dec 2007
          • 71
          Hello, Khun Ninja Copy
          I have canon iR2200. It's show code E246. Can you help me about reset meters . How, Please tell me.
          Thank you
          • Sturay
            E246
            The Error depends on if you have replaced the counter PCB to an old one (from another machine) or if the Counter PCB connection is not fixed properly to the main Controller.
            However it can also depend on if the Counter PCB has reached the maximum reading approx.1.200 000.
            The solution is to put the original counter PCB back into the machine together with the original Main Controller and the original Serial PCB, if the error persist replace the Counter PCB to a brand new one.
            Keep in mind that playing around with these PCB's may end up in an endless problem.
            Good Luck!
            Sturay
            • costd
              • Jan 2008
              • 409
              IF (a big if) you have not been messing around trying to beat/cheat the Counter PCB, an off the wall issue may be the fax modem. Again, IF you have not messed with the Counter PCB (or tried to reset the meter) try removing the fax modem PCB and see if the problem goes away.
              • SCREWTAPE
                Thank you
                no, no, nooooooo
