Canon IR 2270
  • samsaadat
    Canon IR 2270
    Hi every one
    I have a Canon IR 2270 and when scanning a document from the ADF it automatically scans both sides.
    I have tried to go through the copier settings but have not had much luck finding a solution.
  • teckat
    • 16083
    Re: Canon IR 2270
    Originally posted by samsaadat
    Hi every one
    Check the setting in service mode under COPIER>OPTION>BODY>LEVEL 2>SCANSLCT
    to get into Level 2
    (*28* then hit *2 COPIER>OPTION>BODY>SCANSLCT.)
    There are two settings available.
    0: OFF (Determining the scan area by document detection)
    1: ON (Determining scan area by paper size)
    If the setting is "1" the feeder will scan the original twice. Set to "0" for single scanning.
    • samsaadat
      Re: Canon IR 2270
      just tried it and it worked perfectly.
      thank you
      • teckat
        • 16083
        Re: Canon IR 2270
        thank you
        The Dude.jpgWELCOME
        • rkailthya
          Re: Canon IR 2270
          HOW TO SCAN BOTH SIDES OF AN ID CARD AND THEN MAKE 10 COPIES OF IT ON THE SAME SIDE OF A PAPER ON CANON IR2270???
          I ATTACH A PHOTO .
          PLEASE Answer The Question .
          • teckat
            • 16083
            Re: Canon IR 2270
            I ATTACH A PHOTO .
            [ATTACH=CONFIG]19758[/ATTACH]
            That is illegal in USA/ if it has a hologram mark or being used for I.D in Color mode/
            it is ok on B & W mode for a personal copy
            don't know about your country
            why do u need exact back to back
            • rkailthya
              Re: Canon IR 2270
              NO NO NOTHING AT ALL. I NEED THIS BECAUSE MY COMPANY NEEDS AN ADDRESS PROOF OF ME .
              IN THIS ID CARD MY NAME AND ADDRESS IS MENTIONED WITH MY PHOTO. THAT'S WHY I NEED IT LIKE THIS.
              PLEASE HELP ME DUDE.
              • teckat
                • 16083
                Re: Canon IR 2270
                maybe using job build feature on panel
                but better to use photo shop> scan in images to program to set up for two sided printing
                • Chameleon
                  • Nov 2011
                  • 200
                  Re: Canon IR 2270
                  I think what you are looking for is called "Image combination". If it isn't under the 2-Sided shortcut, look under "Special features". A lot of Doctors offices use it to copy insurance cards.
                  The chance that higher life forms might have emerged in this way is comparable to the chance that a tornado sweeping through a junkyard might assemble a Boeing 747 from the materials therein. -Fred Hoyle
                  • teckat
                    • 16083
                    Re: Canon IR 2270
                    don't think "Image combination" will put that ID card Back to Back
                    u could try off the glass 1 to 2 sidedThe 1 2-Sided mode cannot be used with the Two-page Separation, Image
                    Combination, Booklet, or Transparency Interleaving mode.
                    • SashaRoiz
                      Re: Canon IR 2270
                      But it is best to use Photoshop scanned image program is setto double-sided printing
                      • rkailthya
                        Re: Canon IR 2270
                        Thank You For Your Concern Sir. I Will Try 1 to 2 Side And Will Reply You.
                        Sir,
                        Can You Tell Me The Operational Way To Do This Work. (Example: Desktop>My computer> Drives)
                        Thank You ...
                        • rkailthya
                          Re: Canon IR 2270
                          How Could I Find Photoshop scanned image program??
                          • teckat
                            • 16083
                            Re: Canon IR 2270
                            free editor
                            Photo editor online - Pixlr.com edit image
                            scan images in> use print driver to duplex
                            or use
                            or--------------------
                            Top 10 Free Photo Editors for Windows
                            • northernlife
                              • Sep 2011
                              • 847
                              Re: Canon IR 2270
                              Don't forget GIMP
                              Originally posted by teckat
                              free editor
                              or use
                              IrfanView - Official Homepage - one of the most popular viewers worldwide
                              Free Photo Editors for Windows - Top Picks
