Canon IR 6000 Crooked Paper Feed Problem:
  • ybnews
    • Oct 2008
    • 94
    Paper is feeding crooked and jamming in the fuser heat rollers.
    I tested all 4 paper draws.
    Draw 4, (11 x 17) feeds fine but image is crooked.
    Draw 3, (8 1/2 X 11) Letter R JAMS, image is crooked.
    Draw 2, (8 1/2x11) Letter JAMS, image is crooked.
    Draw 1, (8 1/2 x 11) Letter JAMS, image is crooked.
    If I feed card stock, (67 vellum bristol) all draws feed fine (no jams) but image is crooked.
    I suspect a paper register issue but don't know where to look.
    Any suggestions?
    Thanks.
    Dana
  • ybnews
    • Oct 2008
    • 94
    Re: Canon IR 6000 Crooked Paper Feed Problem:
    UPDATE:
    I oiled all the shaft ends of the Fuser unit and duplexing unit.
    Copier now feeds regular paper through all draws (no jams) but image is Way crooked.
    A straight line across the top of the original comes out one inch at the left
    but 1 3/8 inches down at the right.
    What's up there??
    Dana
    Any suggestions?
    Thanks.
    Dana
    • HP:guy
      • Feb 2013
      • 279
      Check the buckle @ registration.
      • Brian8506
        • 1666
        Also check the tension rod for the feed belt in transport. Plastic stoppers break and rod shifts front and back. Alco check that when t/s corona is lifted that the white mylar to the left is not sticking up and catching the passing paper
        • canonbundy
          • Jun 2012
          • 607
          Any suggestions?
          Thanks.
          Dana
          Assuming the Image is already crooked on the paper BEFORE it jams in the Fixing Unit, I would suggest checking the Rollers, Bushings & Springs in the R/H Door also the Springs on the Rego Roller.
