IRC 3220 Blurry colorcopies
  • Digicomm
    • Sep 2010
    • 65
    I have a IRC3220. The copy quality on the black copies are OK. The colors misalign when making color copies. I'm thinking of replacing the ITB. Any other suggestions. Thank's John
  • blazebusiness
    SanDiegoCopierRepair.com
    • 1257
    Re: IRC 3220 Blurry colorcopies
    I'd certainly start with the itb. Sounds like variation in registration for the colors.That'll probably be the fix. Let us know. The transfer belt may be slipping on its drive rollers. You could try to remove the belt & clean up the itb with alcohol.
    • teckat
      • 16083
      iR3200-3220 ITB Issues TP03.pdf
      read-----------
      also check Pattern Reader see pdf---
      Pattern Reader Unit.pdf
      did u check the PG6 (see Example) is issue paper feed (sub-scan) or cross feed (main scan)????
      also take off ITB BELT and inspect the Primary Rollers/
      all must be seated in spring loaded couplings f/r-
      • Digicomm
        • Sep 2010
        • 65
        Thank's for the help.I'll let you know how I make out. John
        • HP:guy
          • Feb 2013
          • 279
          Do a p print then clear the DCON reinput the values
          • SCREWTAPE
            East Coast Imaging
            • 3396
            check this thread out. http://www.copytechnet.com/forums/ca...n+canon+models
            • teckat
              • 16083
              never take the easy way out/ doing this possible temp fix-
              that usually returns after u leave
              if u want to be a tech/ learn to work like a tech/
              learn the correct approach to take on an issue at hand
              • Fer
                • Nov 2009
                • 267
                Clean the drive roller very thorough. Use a rubber cleaner and clean till the roller feels soft and grippy.
