Canon C5185 E000110-0205 error code please help
    • 16083
    Re: Canon C5185 E000110-0205 error code please help
    Originally posted by crwoo
    Ok one of the connectors wasnt totally secured after replacement. now the machine works great.
    THanks for all the help guys. should i throw the bad laser away or does anybody want it.
    did u run FULL AUTO GRADATION & Calibrate Fiery if attached after Laser replacement ?
    did u Print out a new P PRINT to leave by printer or give to key op ??
    Shovel crap.jpgOLD LASER FIND HERE-
    • crwoo
      • 76
      I did a full gradient and fiery calibration, but i dont know how to make a P Print, How do i do that?
        • 16083
        go in service mode------------
        (*add functions key)(#2,#8 key together)(*add functions key)
        COPIER > Function > MISC-P > P-PRINT
        P PRINT has the Printer settings (DCON/RCON/)
        another important ?
        did u read posted pdf and put in the label settings from new Laser in service mode ??
        When the laser unit is replaced, use the appropriate service mode (with the corresponding color) to enter the values shown on the label affixed on the top of the new laser unit.
        it is in service mode-------------------
        Laser Manufacturer ID:
        [1]COPIER > ADJUST > LASER > LA-MK-Y/M/C/K
        Laser Magnification:
        [2]COPIER > ADJUST > LASER > LDADJ1-Y/M/C/K
        [3]COPIER > ADJUST > LASER > LDADJ2-Y/M/C/K
        [4]COPIER > ADJUST > LASER > LDADJ3-Y/M/C/K
        Laser Phase Difference:
        [5]COPIER > ADJUST > LASER > LDADJ4-Y/M/C/K
        [6]COPIER > ADJUST > LASER > LDADJ5-Y/M/C/K
        [7]COPIER > ADJUST > LASER > LDADJ6-Y/M/C/K
        • crwoo
          • 76
          #19
          OK thanks i will do that.
          Yes i followed the procedure for the new laser. the magenta colors looked out of focus before i did it and look nice and sharp now.
          Thanks for the help
          • Cycle Clutch
            • Feb 2013
            • 25
            #20
            Good idea to have P-print with copier. Also print a User Data List for network settings.
