Canon iadv 8295
  • lago
    • Oct 2012
    • 13
    Canon iadv 8295
    Hi Team, I would like to ask for help and apreciate if some one can help me with this beast, is a Canon mdl 8295 every time I try to use the lCT I get a jam erro of 000117 does any one knows what it could be the source I would really apreciate Thanks in advance for any help/guidence
    Lago
  • teckat
    • 16083
    Re: Canon iadv 8295
    Lago
    JAM 0117= is a delay=PS1 Deck Pickup Roller / Paper Deck / POD Deck
    Clean paper dust from sensor & rollers
    Deck feed sensor PS1
    xx = 01: Delay, 02: Stationary, 0A: Residue
    last two numbers xx17 is location of issue/ u need get/buy a manual for the product
    you have-----------click on pic better view--------
    Paper Deck Unit-C1 or the POD Deck Light-A1
    • lago
      • Oct 2012
      • 13
      Re: Canon iadv 8295
      Hi, Thank you for your prompt reply, well I do have one, I have cleaned the sensors with no result I have replaced the pcb controller on LCT with no result so that isolates pcb, now I have not seen one of this LCT's so a'm still traying to figure out how to disassamble the feed section, reading but some what fustraded all ready, like I said 1st timer....., but looking at the feed whls it looks like if there is no spring back tension from snrs, cause when I push the sensors up they get stock in the up wards position some what for a sec. or 2 ?? well a'm still playing with this
      • lago
        • Oct 2012
        • 13
        Re: Canon iadv 8295
        Well... I cleaneed snrs swap them with no avail. so I will have to replace the feed assy, just don't want to because it has a lot of stuff I know there is something funny on these feed assy.. on the spring action etc... I just have not seen one before so I don't know how it is assebled......
        • teckat
          • 16083
          Re: Canon iadv 8295
          Which DECK do u have ??
          why are u change the feed unit ??
          • kronical
            Kronic Copier Ninja
            • Nov 2009
            • 230
            Re: Canon iadv 8295
            You just answered your own question.
            Follow the spring tension on the actuator. If it's not returning properly, of course it's going to jam.
            • lago
              • Oct 2012
              • 13
              Re: Canon iadv 8295
              Hello:
              Back in the saddle againg I tought it was spring tension but not! D...m I replaced the entire feed assy comes complete clutch etc. nothing same error what I have replaced so far LCT main pcb and feed assy every D...m yhing looks ok there's not much on this error 0117
              Any ideas............
              Thank you Lago
              Btw I compare the new feed assy to the new and is just the same nothing diferent than the other.
              is an Pod Deck Lite A1
              • lago
                • Oct 2012
                • 13
                Re: Canon iadv 8295
                Hello back here:
                I've got the manual for it but there's not detail on the error manual does not even shows error list!!! WTF. now I got the service manual for the Engine and same crap...!!! really all it reads is 0117 delay jam Relly????? Man!!!!!!!!!!!!!
                Lago
                • vigour
                  • Aug 2010
                  • 1038
                  Re: Canon iadv 8295
                  The info given before shows that 0117 is a pickup jam.,
                  Paper is not reaching the first sensor in time.
                  LEAVE THE TOP OFF THE DECK and watch if the rollers turn.
                  If they do turn , then check if the Deck Tray is even.
                  You may be having some issues with the CABLES.
                  The Tray might not be high enough
