IR 5075 ADF Margin Problem
  • saidone
    • Mar 2012
    • 12
    My copier IR 5075 has a margin problem when using the ADF for foolscap paper (size 33 cm long), different from the original 0.5 cm, but there is no problem for A4S size paper. How to solve it? Who can help?
    Thanks.
  • canonbundy
    • Jun 2012
    • 607
    Re: IR 5075 ADF Margin Problem
    Check and read carefully the 'Installation' Section of the Service Manual, it reveals All.
    • teckat
      • 16083
      Thanks.
      service mode > in LEVEL 2
      COPIER > OPTION > BODY
      SCANSLCT
      Use it to enable/disable the function used to compute the scan area from the selected paper
      size.
      setting
      0: off (determine scan area by original detection)
      1: on (determine scan area by paper size)
      ORG-LGL Use it set a special paper size that the ADF cannot recognize (applicable to LGL
      communicated by the ADF).
      setting
      0: LGL (default)
      1: FOOLSCAP
      2: A-FOOLSCAP
      3: FOLIO
      4: G-LEGAL
      5: OFFICIO
      6: E-OFFICIO
      7: A-OFFICIO
      8: B-OFFICIO
      9: A-LEGAL
      10: M-OFFICIO
      A4 =______210 x 297 mm 8.3 x 11.7 in
      Foolscap =_203 x 330 mm 8.0 x 13.0 in
      Legal =____216 x 356 mm 8.5 x 14.0 in
      • saidone
        • Mar 2012
        • 12
        Thank you. techcat
