canon ir7095
  • tongee
    • Nov 2009
    • 50
    canon ir7095
    Image gray haft sheet.
  • teckat
    • 16083
    Re: canon ir7095
    Help me[ATTACH=CONFIG]19456[/ATTACH]
    is issue on Prints and glass Copies
    Pre-Exposure lamps
    Negative> Positive
    • tongee
      • Nov 2009
      • 50
      Re: canon ir7095
      Pre-Exposure lamps
      Negative> Positive
      [ATTACH=CONFIG]19457[/ATTACH]
      I print report from the Machines
      • teckat
        • 16083
        Re: canon ir7095
        make some test of the Glass and post them
        • Herrmann
          • Jan 2006
          • 792
          Re: canon ir7095
          Stop the printing/copying process of large format while working by opening the front door. The mashine will stop imedeatly. How does the toner picture on the drum surface looks like? Do you use original canon toner?
          Maybe the pre exposure lamp, as teckat suggest is bad, but i would assume, that in this case the potential control would freak out, throwing an e-xxx error.
          Take out the developing unit and have a look at the developer roller, is the toner coating equal? what about the distance rollers? are they ok, not worn out or blocked?
          Drum scraper ok and not blocked in movement?
          The picture is really small, but it seems, that the "print free areas" (sorry, i dont know how to spell it correctly) are coated also, so at last a laser error may be possible too.
          If sometimes you feel a little useless, offended and depressed always remember that you were once the fastest and most victorious sperm of hundreds of millions!
          • Rachid.Akli
            • Oct 2011
            • 595
            Re: canon ir7095
            Hello,
            This seems to be a drum potential issue.
            Keep in mind that in this model the laser "writes"
            In COPIER > DISPLAY > DPOT, reccord and compare the following values:
            1- VL1T: Is the reference value of the drum potential when the laser is "ON".
            VL1M: Is the measured value of the drum potential when the laser is "ON".
            VL1M = VL1T +/- 10 volts.
            If this is note the case, there is a laser intensity issue and the prints will be lighter.
            2- VDT : is the reference value of the drum potential when the laser is "OFF"
            VDM : is the measured value of the drum potential when the laser is "OFF"
            VDM = VDT+/- 10 volts
            If this is not the case, there is a drum potential issue: Primary corona, HV PCB, Preconditining lamps... The white surfaces of the prints are darker.
            Rachid.
            "Find a job you love and you’ll never have to work a day in your life." Nagy's father
            • canonclc
              • 71
              Re: canon ir7095
              Looks like a toner issue to me .try vacuuming the dev unit out and adding fresh from the bottle by pouring some in .
              Used to happen on np copiers with crap toner from 3rd parties
              • teckat
                • 16083
                Re: canon ir7095
                Originally posted by Rachid.Akli
                Hello,
                Rachid.
                When does the LASER not write in an imageRunner ??
                • Rachid.Akli
                  • Oct 2011
                  • 595
                  Re: canon ir7095
                  -In IR5000, IR5570, IR6570, IR5055, IR5065...the drum surfaces that are "hit" by the laser will not receive toner. They correpend to the white surface .We say that the laser "erases".
                  - In most of the other models, the drum surfaces that are "hit" by the laser will receive toner. They correspend to the image surfaces. We say that the laser "writes"
                  Rachid.
                  • teckat
                    • 16083
                    Re: canon ir7095
                    Rachid.
                    Extra-Extra.jpgKOOL'; after 26 years, should know that/
                    • tongee
                      • Nov 2009
                      • 50
                      Re: canon ir7095
                      • Herrmann
                        • Jan 2006
                        • 792
                        Re: canon ir7095
                        Clean Laser Unit thoroughly and adjust primary corona wires, this should do the trick.
                        • tongee
                          • Nov 2009
                          • 50
                          Re: canon ir7095
                          ok thank everybody this time the machine it fix.
