Canon c5185 E000003-0001 Fuser error code please help
  • crwoo
    • 76
    Hi, I solved my Laser problem yesterday, and this morning my Canon C5185 got the E000003-0001 error which i gather is the fuser. and fusers are expensive. any chance I am wrong or I can reset the error?
    Please help.
  • teckat
    • 16083
    Re: Canon c5185 E000003-0001 Fuser error code please help
    Please help.
    I would first check your wall voltage outlet
    hot>ground=
    hot>neutral=
    neutral>ground=0v>0.5v max
    E003
    E003 indicates fixing unit low temperature trouble.
    how old is fix unit ??????????????
    • crwoo
      • 76
      I replaced the heating element in the fuser (i had one and thought it might solve it) and not after the reset everything works fine! Thanks teckat and this forum
      the fuser is still original and the machine has 500,000 copies.
      • teckat
        • 16083
        500,000 prints and original fuser in 5185 ??
        have to question that are u sure/ positive ?
        • crwoo
          • 76
          i cant confirm it, i got it with 250 and added 250 and when i got it the fuser was a bit brownish and deff not new.
          • teckat
            • 16083
            may have been replaced before u got it
            250,000 seems ok / be careful / do u have access to refurbish fix units
            • crwoo
              • 76
              no i dont know of any and why do you ask? can you refurb them? mine might need a new belt. not perfect.
              • teckat
                • 16083
                I'll bet your unit has been replaced before
                I don't' refurbish them/ If u can find time and parts & obtain knowledge on the fuser unit u might have success/
                replacing just the upper belt is not always successful -there are no instructions on just single belt replacement
                here are some old pdf's on fuser unit
                5185_007 Checks.pdf
                Disassembling and Reassembling_Fixing Unit_TP07-168.pdf
                • canonbundy
                  • Jun 2012
                  • 607
                  FIVE HUNDRED THOUSAND - hahahahahahahahahahahahahahahahahahahahahahahahaha hahahahahahahaha
