image runner 2022i
  • wtomes
    • Aug 2025
    image runner 2022i
    light on the start button won't light and the machine will not copy or print. power up and down still the same problem
    donot have a service manual. Is there a reset?
  • zoraldinho
    teacher-guide-expert-guru
    • Mar 2008
    • 5017
    Re: image runner 2022i
    There is no reset. Do you have light in the room?
    • copicatt
      • Nov 2008
      • 366
      There are no messages on the screen? paper, jam, code????
      • teckat
        • 16083
        do other buttons on the touch screen and control panel function at all ????
        Can u press and hear a click on release of start button ?
        if yes/ remove > clean and re-seat memory
        if not see below
        check for a stuck button or broken underside tab
        yours may look differant
        also check
        J318- Control panel connection slot
        on image Processor pcb
        • Kings
          Steve@Kings
          • Nov 2009
          • 79
          This sounds as if the scanner is online.......Mmmmmmm.
          Check and make sure its offline. You never know..
          • JustManuals
            • Jan 2006
            • 9838
            Paul@justmanuals.com
