Canon ir1133if - E355
  • dickiebob
    • Sep 2011
    • 66
    [Error Code] Canon ir1133if - E355
    IR1133IF - display is upside down with japanese writing and showing error E355. Unable to enter service mode or any other mode.
    Any ideas?
  • Rachid.Akli
    • Oct 2011
    • 595
    Re: Canon ir1133if - E355
    Any ideas?
    Hi to every one,
    E355 Error codeI am not sure of the following: If your machine is networked, use its IP address to enter the Remote Unite Interface and choose the displaying language.
    Rachid.
    "Find a job you love and you’ll never have to work a day in your life." Nagy's father
    • Rachid.Akli
      • Oct 2011
      • 595
      Any ideas?
      Hello again,
      The fact of not being able to enter neither the service mode, nor the user mode is a consequence of the E355 error code.
      Rachid.
      • teckat
        • 16092
        Any ideas?
        MNCON clear may resolve the Japanese issue.
        or re-install the System Software.
        like this in English version
        Try Refitting all the harness connections within the control panel assembly
        E355 is another issue
        E355 error may appear after replacing the Counter Memory PCB
        what did u do before ERROR ??
        were u swapping pcb's
        Japanese ??? what was it before ??
        don't know or think if your model supports this below
        To clear an E355 code, access Level 3 of Service Mode. This can be done by following the procedures below.
        - Press "*", then Press "2" and "8" simultaneously, then Press "*"
        - Press " * ", then Press "1" and "9" simultaneously, then Press "3"
        - Press Copier / Function / Clear / E355 , then Press OK and then Press Reset
        - Turn the machine off, then on using the main switch which is located below and to the rear of the bypass tray.
        DO NOT MAKE ANY CHANGES IN LEVEL 3 SERVICE MODE. Only used for the E355 clear.
        Any adverse affects on the machine will not be supported by Canon USA if Level 3 service modes are adjusted.
        or maybe this---------------------
        Procedure for Clearing the Code:
        1. Enter the Service Mode - Additional Function - then hit the # Key
        2. Scroll(arrow)to #12 Clear - then hit the Set Key
        3.Scroll (arrow)to ERR - then hit the Set Key
        4. E355-CLR will be displayed - then hit the Set Key to clear the E355
        5. OK should display - then the machine will return to the Standby Screen
        or
        E355
        error code is due to no communication between the Main-Controller board and the Serial Number board below it. The boards are connected by a 11 PIN yellow connector and cable. This yellow connector must be reseated on the new Main-Controller board when changed. The connector must be seated firmly on the board.
        1. Enter Service Mode: Press * Additional Functions, 2&8 simultaneously, then * Additional Functions again.
        2. Then select the [COPIER] option. Under [COPIER], select the Function tab.
        3. Under the [FUNCTION] tab, select the [CLEAR] option.
        4. In [CLEAR] there is a selection E355-CLR. Select it and hit OK.
        5. Reboot the machine.
        • dickiebob
          • Sep 2011
          • 66
          or
          E355
          Thanks, but the machine does not let us get in to service mode. We have managed to get it back to an English display, but it is still upside down. None of the buttons on the control panel work. Machine has only done 5k.
