CANON IR 3245N
  • ivanusicnm@gmail.com
    • Oct 2012
    • 22
    [Error Code] CANON IR 3245N
    Heelo,
    i have problem with machine. When i turn on, the displey shows; remainig data that is not needed is being erased.do not turn of the main power.
    How can i erased this.
    Thx
  • Luther
    • May 2006
    • 682
    Re: CANON IR 3245N
    Problem :
    The message "Remaining data that is not needed is being erased. Do not turn off the power" will not clear.
    This is a normal message when powering on a machine with the optional HDD Data Erase Kit-B2. In this example the message would never go away.
    Solution :
    Replacing the Hard Disk Drive (HDD) resolved the problem. The part number for the HDD is FM3-5634-000.
      • Oct 2012
      • 22
      Re: CANON IR 3245N
      Can i resolve the problem, if preform hd format?
      • canonbundy
        • Jun 2012
        • 607
        Re: CANON IR 3245N
        You need to have SST or UST and the latest Firmware, also how to knowledge before attempting any of the above.
        • charm5496
          • 2387
          Re: CANON IR 3245N
          Heelo,
          Thx
          Your machine has the data erase kit installed on it. You would need to uninstall it in or deactivate it in order to remove the message from the machine during the boot up sequence. It is just clearing RAM and the partition of the HDD where temporary image data is held...nothing more.
