Help irc 3220 copy yellow
  • cesarkazu
    • Jun 2012
    • 28
    Hi, friends
    Please, I can not solve this problem, the first copy comes out perfect, afterthe fourth copy begins to yellow
  • charm5496
    • 2387
    Re: Help irc 3220 copy yellow
    are you using after market toner and drums? You are at the mercy of their quality and procedures is you are.
    Obviously I would start by seeing if the drums needed replacement or not and replace as needed.
    Make sure your ITB and transfer rollers are in good shape and clean as needed.
    always run autogradation in the morning and before starting long copy or print jobs
    • cesarkazu
      • Jun 2012
      • 28
      Toner is original and new, original drum and you roughly 15,000 copies, happens only in yellow
      thanks
      • charm5496
        • 2387
        original is highly doubtful. This model is 13 years old now. Are the items Canon OEM or not?
        you are going to have to do some basic troubleshooting in order to repair the issue.
        • yomba
          • Jul 2012
          • 37
          Have you tried to flash the machine or upgrade the firmware? I would start there.If I remember correctly there are two colour boards on that serries, one board controls two colours. Try to switch the boards and see if the problem follows the board.
          • Fer
            • Nov 2009
            • 267
            If u print such kind of prints, with very much color all the time, your drums can be end of life within 15000k. Especially when using heavy paper and non-oem drums.
            I've got a set of C-EXV 8 drums in my car, they are not old...
            • teckat
              • 16083
              thanks
              is issue on glass copies only ?
              looks like edge erase is ok-----------
              are u using thick paper mode ???
              if so >Perform the auto gradation, full, using the THICK PAPER button selected.
              make sure to use the customer thick paper with thick paper type high lighted when making the three test prints.
              if so >CCD adjust>then full auto gradation
              Reader Controller
              • cesarkazu
                • Jun 2012
                • 28
                Reader Controller
                already did these procedures, forgot to inform what happens in most
                heavy paper, paper 90g/m2 takes longer to appear (+/- after 30 copies or prints)
                whether copy or print
                thanks, best regards
                • teckat
                  • 16083
                  just remembered this> I never select the HEAVY PAPER SELECTION on this model> for printing/or copying or AUTO GRADATIONS--- Learned my lesson long ago--
                  Listen to this>> 90G is not HEAVY PAPER-
                  -Heavy 1 paper is from 28 lb bond to 110 lb index (106 to 209 g/m2).=CAN BE USED IN ALL PAPER FEED LOCATIONS--
                  -Heavy 2 paper is from 80 lb cover to 140 lb index (210 to 253 g/m2)=CAN ONLY BE USED IN BYPASS(MF)TRAY
                  FIX--------DO NOT SELECT HEAVY PAPER or do a FULL AUTO GRADATION selecting the HEAVY PAPER SELECTION/ USE THE PLAIN PAPER SELECTION FOR FULL AUTO GRADATION CASSETTES & MF LOCATIONS
                  when u have the amount of coverage % shown on that document > especially on 90g heavy paper the volume shown at 15,000 means a big "0" that document is about 75/80% coverage>at that pace your drums especially in this model crap out-
                  It's the Drum memory that breaks down during a constant run
                  could also be a DDI-S PCB issue if only from glass and only yellow-------------------
                  Also Check the four bias tabs on the Drum Unit Cover. The bias tab may be pushed in and stuck. If the tab is stuck in, it will create a poor contact to the bias tab on the drum unit resulting in background on the copies. There is one tab for each drum.
                  • cesarkazu
                    • Jun 2012
                    • 28
                    thank you
                    • teckat
                      • 16083
                      thank you
                      have u worked on situation as of yet ???
                      • cesarkazu
                        • Jun 2012
                        • 28
                        if I use heavy paper, glossy or other type paper, calibrate with heavy1/heavy2
                        if use normal plain paper calibrate with plain paper
