Clear Toner on C1+
  • Alex ahir
    • May 2012
    • 125
    [Misc] Clear Toner on C1+
    Hello guys,
    We have canon IPC1+, it has clear toner installed but when we installed driver it show clear toner off. how to make clear toner on. it not showing even on the main page clear coat.
    thanks for your help
  • zoraldinho
    teacher-guide-expert-guru
    • Mar 2008
    • 5006
    Re: Clear Toner on C1+
    When the machine has warmed up, enter Service Mode: <<Copier > OPTION > BODY > CLCONFIG>> and check if
    set to <0>.
    Server model??
    • Alex ahir
      • May 2012
      • 125
      Thank you so much, its was 1
      • Alex ahir
        • May 2012
        • 125
        Hey ita showing on the main screen now but in the driver device setting clear toner is showing off
        • zoraldinho
          • Mar 2008
          • 5006
          1) Update driver info
          2) server model?
          • Alex ahir
            • May 2012
            • 125
            Its T1 ver. 2 with ps driver
            • zoraldinho
              • Mar 2008
              • 5006
              QuickGuide_intro_A4_v1.doc
              QuickGuide_ClearCoat_draft.pdf
              Clear toner FreeFrom.pdf
              • Alex ahir
                • May 2012
                • 125
                Thank you so much for your help
                • zoraldinho
                  • Mar 2008
                  • 5006
                  No problem. Feedback please
