canon ir 105
  • naveencopier
    • Oct 2009
    • 26
    canon ir 105
    canon ir 105 tray load paper signal tray 1 3 and 4 tray 2 will work
  • zoraldinho
    teacher-guide-expert-guru
    • Mar 2008
    • 5007
    Re: canon ir 105
    Anagram??
    • charm5496
      • 2387
      Re: canon ir 105
      Maybe trying to say that they get a load paper message in 1, 3 and 4 or jams from those trays?????
      the message was definetly lost in translation
      • naveencopier
        • Oct 2009
        • 26
        Re: canon ir 105
        Yes that's what I mean
        • naveencopier
          • Oct 2009
          • 26
          Re: canon ir 105
          Please do you have any suggestion
          • PJFixIt
            PC Guru
            • Sep 2010
            • 20
            Re: canon ir 105
            I have this problem too on my iR105. Only left tray works, all others keep throwing "load Paper" message . Can some one please post a fix or what to look for?
            • aco.bk
              • Sep 2012
              • 130
              Re: canon ir 105
              Did You reset DCon?
              When You want to clear Mn-Cont,DCon,... always first print PPrint then perform reset.
              If You already have PPrint then input values from it.
              For Load paper message on TRAY 1,3 and 4 go to Service mode-Copier-Option-CST-ADJ and input values before reset.
              Check sticker on main door and input values from it.
              PPrint from iR7086 in attach.
              Sorry on bad English.
              • dan7777
                • Dec 2012
                • 680
                Re: canon ir 105
                Have you taken out tray one and looked behind it for a piece of paper? They get a jam, open drawer and paper falls behind tray when it is closed sometimes.
                • PJFixIt
                  PC Guru
                  • Sep 2010
                  • 20
                  Re: canon ir 105
                  Thank you all. I have done all the above including changing DC PCB from another machine, DC-CON cleared, reprogrammed but nothing helps. Checked sensors and sensors from all 4 trays are sending proper signal on DC-con P004 etc. when tested with trays and manually without trays. Can't figure out from service manuals, what is common to Right Tray, C3 and C4 that sends "Load Paper" on the console. Perfectly working all 4 trays, 5 days ago now, only Left Tray works now. Any other service techs, please respond.
                  • PJFixIt
                    PC Guru
                    • Sep 2010
                    • 20
                    Re: canon ir 105
                    I just want to update my finding. First, thanks to Teckat for directing me towards checking the Optical Sensors for Right tray, which was NG!. All other sensors were fine. I cleaned it and the reflector on the side door. Next morning everything checks out and all trays work! It turns out, if right tray sensor fails, it knocks out C3 and C4 too (like Christmas lights!). Once I fixed the failing sensor, all trays come alive..go figure! No where in the service manual, it says that. Good luck.
                    • Danowl
                      Re: canon ir 105
                      Change all sensors from tray 1 to tray to 4, reset dc con turn machine off and then on withtray 4 open. If tray 1 works replace all sensors from tray 4
