somethig wrong with pg 10
  • pc123321
    • Dec 2012
    • 103
    maybe i can guess the problem what it is
    may i a trouble people
    what is wrong wiht pg-10 pic
    last time is magenta drum
    this time will be yellow or next cyan
  • Herrmann
    • Jan 2006
    • 792
    Re: somethig wrong with pg 10
    I dont know, what mashine, but it looks like you should clean Cyan Laser at least
    If sometimes you feel a little useless, offended and depressed always remember that you were once the fastest and most victorious sperm of hundreds of millions!
    • teckat
      • 16083
      if this is from 3200 or 5180 series/
      remove ITB>remove ITB Sheet> and inspect the CYAN Primary transfer roller/
      make sure it is in place > snapped in holders both sides
      see example (on yellow below)
      • JR2ALTA
        • Feb 2010
        • 2033
        [ATTACH=CONFIG]19628[/ATTACH]
        that was mighty kind of you
        • Fer
          • Nov 2009
          • 267
          If this is a IRC2880 or like, u can start by cleaning the laser windows by hand. Since they are underneath they tend to collect dust.
          • teckat
            • 16083
            2880 SERIES
            glass is located under each unit and may have toner spilled on it. Clean the glass with the tool provided on the front door. Instruction's are also included there.
            • pc123321
              • Dec 2012
              • 103
              this is the machine canon c3220 ---
              last thursday i took out the ibt belt -seen the inside roller ,it seem that a yellow toner spread on its surface
              i cleaned and put it back and found ,its still have the yellow toner after 5 printout on the paper at its left hand side
              so this time i print out the pg10 pg6 ------------
              i saw the number on the yellow drum ---c8560 , for hp 9500series drum ?
              a ebay seller make this modification----
              you see,,,,,,,,,,, pg10 shown ,my next problem will be cyan ---this time is the yellow , but
              last time drum life checked as following
              yellow 1, magenta 29 cyan 23 black 51
              yesterday i check again
              yellow 15 magenta 4 cyan 30 black 58
              thanks fer, and tekcat ,your other post of the ibt pic.s
              • teckat
                • 16083
                u are buying modification hp drums on eBay for your 3220 and u are looking for help
                on non to very non OEM drums
                what other non things are u using in a USA ACCOUNT
                • pc123321
                  • Dec 2012
                  • 103
                  i bought on ebay ,c3220 drum , it show on screen , all are c3220 remanufactured by seller ,but i saw one buyer feedback , one complaint that's not canon drum
                  the drum said itself as a hp product---- how a drum life(include remanufact) can last ,?
                  supposed a drum 40000 pages at 5% condition , itf seller change develope , toner,chip and roller ,
                  we can expect after 40000 pages for those parts replace , what is the buyer wish the pages he can print
                  活該 --in chinese word 貪小失大,,,the same meaning ,buy any remanufactured drum , you will got the return some day
                  • teckat
                    • 16083
                    Never buy re-conditioned or re-manufactured drums from e-bay/
                    how do u expect someone here to identify a CQ Issue on these drums---------
                    Remember this
                    u cant' believe all u read on e-bay claims
                    • charm5496
                      • 2387
                      my dad always told me you get what you pay for in this world. it seems to me that you are experiencing his words of wisdom.
