ir 2520 contrast in copy problem
  • pulkit jain
    • Dec 2012
    • 73
    ir 2520 continously giving a very low contrast copy i had changed the toner, properly clear the developing unit, changed the drum
  • Hitesh_honey
    • Aug 2011
    • 19
    Re: ir 2520 contrast in copy problem
    pl clean transfer charger also
    • zoraldinho
      teacher-guide-expert-guru
      • Mar 2008
      • 5017
      Print is OK?
      • teckat
        • 16083
        is image light or washed out on copies, print jobs and internal test prints ???
        is density uneven on entire image on page ?
        Did u inspect & clean the Transfer Roller and inspect the toner brush on the Developer
        see example>>> is this like yours ??
        Inspect contact on the HVT / may be stuck out of position causing the light images.
        Reposition the contact.
        Please the photo below for the location of the contact.
        this pdf below is for uneven density fix -middle of page
        Measure to Prevent Uneven Density in the Center of the Page.pdf
