I am getting an error code of E000204-0001. I have turned the power source on and off several times and then is fine until I try to copy something. Could anyone help please?
Thank you,
Faith
u mean a E204 CODE ???
E204 (image leading edge detection error) -The ADF does not generate the image leading edge signal in stream reading mode. COPIER>ADJUST>ADJ-XY>ADJ-X (scanner image leading edge adjustment)COPIER>FUNCTION>CCD>SHDG-POS (shading position adjustment)
Thereafter, make a test print to be user that no white line is found in its halftone area.
Range: 240 to 320 (a multiple of 8 causes a shift of about 0.17 mm)
----------------------------------------------------------------------------------------- try above first
E204
0001 =While an original is being read, the image leading edge signal does not arrive from the ADF.
Main cause =The ADF controller PCB is faulty. The reader controller PCB is faulty.
Caution When this code occurs, no code is indicated, but the keys are locked. The
code may be checked in service mode: COPIER>DISPLAY>ERR.
------------- 1. Read sensor (S2)
Try replacing the read sensor of the ADF. Is the problem corrected?
YES: End. 2. ADF controller PCB, Reader controller PCB
Try replacing the ADF controller PCB. Is the problem corrected?
YES: End.
NO: Replace the reader controller PCB.
