Canon ir5075 E0061
  • hamdyyassin
    • 84
    Canon ir5075 E0061
    I have an error E061-0001 in my copier ir5075 .I cleaned potential control sensor and the primary corona unit but the same error happend after warming up without copying any paper.
    When i turn off po-cnt it prints about 50 papers and give E061-0002 then i clear the error, it workes again and prints about 50 papers , the same error e061-0002.
    Thanks for help.
  • zoraldinho
    teacher-guide-expert-guru
    • Mar 2008
    • 5005
    Re: Canon ir5075 E0061
    copier counter (drum life)??
    Inspect laser assy (shutter).
    Potential sensor PCB faulty?
    • Fer
      • Nov 2009
      • 267
      How is the primary corrona? How is Tp3 with po-cnt disabled?
      • charm5496
        • 2387
        sounds like it is time for a potential control sensor and board or a new laser unit. The laser could be getting weak causing the issue
        • Cycle Clutch
          • Feb 2013
          • 25
          Check connectors on back frame of copier behind slide out transfer/fixing assy. units for torn paper. Check both male and female connectors.
          • pawankchopda
            opne laser unit aftr clen mirrer motar /potential control sensor allows on
