coping has been reserved !
  • canonclc
    • 71
    Main controller 2 was replaced with the settings from p print put back in.
    Green copy light comes on but when pressed the screen displays coping has been reserved but scanner does not move.
    (Stapler has been checked ) same using df
    Scanner switched off and back on innservice mode .this is on an irac5051
    Any ideas ???
    Ps, prints ok
  • teckat
    • 16083
    Re: coping has been reserved !
    Any ideas ???
    Ps, prints ok
    Any set restrictions
    using /or under System Mgr>
    Management Settings>
    User Management> Department ID Management
    is "Limited Functions"
    shown
    Online or Offline set ?
    • vigour
      • Aug 2010
      • 1038
      set SENS-CNF to 1
      • canonclc
        • 71
        Originally posted by vigour
        set SENS-CNF to 1
        Is this in option or function ? And what does it do?
        • canonbundy
          • Jun 2012
          • 607
          Any ideas ???
          Ps, prints ok
          Why did you replace Main Controller 2 in the first place?
          • canonclc
            • 71
            Intermittent e100 for bk laser and yellow laser.
            Swapped dc con with no joy
            So fitted new mn con 2
            • vigour
              • Aug 2010
              • 1038
              set SENS-CNF to 1
              service mode level2
              copier> option> body> sens-cnf change to 1
              I would update/reload firmware
              • teckat
                • 16083
                Any ideas ???
                Ps, prints ok
                or scan. on an iRAC5051
                did u test internal test prints ? do they print ??
                Copy jobs go to the scheduled cue but do not print.
                from CANON ------
                The symptom was further clarified and partially duplicated by removing the crossover cable after the machine was ready.
                Suspected a communication problem with the cabling.
                Checked the cables and found that there were no video cables connecting the server to the engine.
                The tab connection on one end of the cable was plugged into the copier and the non tabbed end was plugged into the other connector on the copier.
                The same was true for the server side.
                After properly connecting the video cables so that the copier had a tabbed connection on one side and the non tabbed connector of that cable was going to the server and vise versa for the other cable, the copies printed normally.
                The server had to still be configured and tested to ensure the calibration and other functions were normal.
                No other problems found.
                • canonclc
                  • 71
                  from CANON ------
                  Got to have a look at the m/c last night myself & found that it had copytrack installed. Switch off copytrack and it worked
                  .put the original board back in and copies ok with copytrack turned on.the mc will scan ok and print internal prints ok just not copy with the new board.may be meap firmware issue that needs updating. So I will go back in and try that next &let you guys know .
                  Thanks for the help so far .
                  • canonbundy
                    • Jun 2012
                    • 607
                    E100 on all Canon boxes refers to the BD Signal to a Laser Unit.
                    Note the Sub Code.
                    Did you try swapping the K & Y Laser Units with M & C to see if a different Sub Code was generated?
                    These Units are connected in Pairs, so determining the faulty Laser can be time consuming - But there will be only 1 that is faulty.
                    • canonclc
                      • 71
                      Note the Sub Code.
                      Sub code related to both laser units hence changing the boards (did replace the bk/cyan laser)
