canon error
  • falah taan
    • Feb 2013
    • 67
    [Error Code] canon error
    inave error in canon ir c3220 code E00020 04c0
  • kuby
    • Oct 2007
    • 1396
    Re: canon error
    Black drum unit, may need replacing.
    • falah taan
      • Feb 2013
      • 67
      Re: canon error
      i replac black dram unit but it still the same error
      • kuby
        • Oct 2007
        • 1396
        Re: canon error
        Did you clean inside the machine and the sensors?
        • JustManuals
          • Jan 2006
          • 9838
          Re: canon error
          Paul@justmanuals.com
          • SCREWTAPE
            East Coast Imaging
            • 3396
            Re: canon error
            Is it an OEM drum. What about your transfer belt? How old is your transfer belt. Images are transfer to the belt after images are written to the drums. What are density readings like for black and what about your window readings?
            Come on techs!!!
            • teckat
              • 16083
              Re: canon error
              Come on techs!!!
              xx=01: Y
              xx=02: M
              xx=03: C
              xx=04: Bk
              E020-04C0========The supply of BLACK Toner for the toner container to the developing assembly is faulty.
              ATR sensor has an open circuit.
              either over add or under add of toner
              The fault occurs when an image is being formed.
              u need to check your ITB UNIT
              where are u getting your toner units from
              check if the shutter under the toner cartridge is functioning
              ATR Control
              The machine executes ATR control to maintain a specific image density, which otherwise would change as more and more toner is used. The machine measures the concentration of toner and adjusts its supply.
              Determines the volume of toner to be supplied
              ATR Reference is taken off BLACK PATCH FIRST
              Have u ever calibrated your printer ??????????
              Have u checked your PATCH SENSOR ??
              CLEAN SENSOR
              • teckat
                • 16083
                Re: canon error
                another thing to check is the swing gear unit> this drives the ITB into correct position
                if teeth are worn or damaged>cause skip over and no or poor drive to ITB to pick up image u can have various e020 codes
                SWING HELICAL(////) GEAR MESHES WITH ITB GEAR(\\\\)
