IR ADV C2020 copy not aligned
  • jaim3naps
    • Feb 2013
    • 29
    Hi, i have a problem on IR Adv C2020 when making copy/printing colored the magenta is making shadow. how to adjust this. i already do the auto gradation 2x, but still same thing. here is the sample i created exactly same thing when i printed the test page type 10. any one have issues like this? by the way the laser scanner unit is new.sample test print.pdf
  • teckat
    • 16083
    Re: IR ADV C2020 copy not aligned
    Originally posted by jaim3naps
    Hi, i have a problem on IR Adv C2020 when making copy/printing colored the magenta is making shadow. how to adjust this. i already do the auto gradation 2x, but still same thing. here is the sample i created exactly same thing when i printed the test page type 10. any one have issues like this? by the way the laser scanner unit is new.[ATTACH]19766[/ATTACH]
    Run a color mismatch
    Did u check & re-seat Magenta Drum ? this out of position happens
    DC CON Clear ? /make sure u have your settings printed out before or door specs
    Swap the mis-registered laser with another on the machine. Perform an AUTO COLOR MISMATCH, then perform <COPIER>FUNCTION>LASER>LEVEL-2> for each color, then perform AUTO GRADATION. If problem persists, then replace the laser assembly for M color.
    • jaim3naps
      • Feb 2013
      • 29
      Yes i did reset the drum many times.
      i cant swap the laser of any colour because its in the whole unit of laser scanner assy.
      i haven't do the color mismatch yet. Ill try that next visit.
      and i have the same machine in the field after replacing the yellow drum get E0020 1060
      and put back the old drum sometimes error come out with E0020 0060 5.
      any idea how to fix this?
      • teckat
        • 16083
        forgot about that it's one Laser unit on IRADVC2020
        may then boil down to Laser U or DCpcb
        DC Controller outputs the laser control signal to the Laser Driver IC on the Laser Driver
        PCB which is in Laser Unit
        have u tried a new M Drum
        • jaim3naps
          • Feb 2013
          • 29
          no not yet replace the magenta drum.
