E025-0210 iRADVC5051
  • magc
    • 30
    Hi I have a Canon copier iRADVC5051 with error code E025-0210. What could be the problem? Thank you.
  • teckat
    • 16083
    Re: E025-0210 iRADVC5051
    imageRUNNER ADVANCE C5030 / C5035 / C5045 / C5051
    imageRUNNER ADVANCE C7055 / C7065 / C9065 PRO / C9075 PRO
    E025
    code did not need to be reset by doing the ERR Clear in service mode.
    There are a few E025 codes listed on the imageRUNNER ADVANCE series that Do Require a clear to be done.
    Best practice for any E025-XXXX code
    on the imageRUNNER ADVANCE series is to clear the code in service mode and reboot the machine to see if it resets. If it does not clear, trouble shoot the device for that code. Always perform the clear after swapping or replacing any parts related to E025-xxxx codes.
    u mean e020-0201
    Error in Y Developing Assembly
    The value is lower than the lower limit for the patch.
    • jmcwhirk68
      E025
      u mean e020-0201
      I have found the E025 code to be the X gear stripping out on the rear of the developer assy'. Hope this helps.
