IRC 1022i Firmware and Service Support Tool needed
  • kenli
    Urgently needed. Can someone help?
    my eMail is : ken.li.it@gmail.com
  • teckat
    • 16083
    Re: IRC 1022i Firmware and Service Support Tool needed
    imageRUNNER C1022i / C1022
    The software used to flash this model is called the User Support Tool.
    The Service Support Tool is not used in flashing this model imageRUNNER.
    firmware will include the User Support Tool.
    Read-------------iRC1022 Flashing procedure.pdf
    NOTE:
    imageRUNNER C1022 / C1022i
    How to get into download mode when service mode is unavailable
    1) Power on the laptop and connect to the machine via a USB cable.
    2) Hold down the #2 key and turn on the machine.
    3) Keep holding the #2 key down until the "USB DOWNLOAD AVAILABLE" message is displayed.
    Note: The machine will cycle, the progress bar screen will come on and go off. Keep holding the #2 key until the download message is on the screen.
    4) Now you can start downloading the SSW.
    • amg76
      Read-------------[ATTACH]19780[/ATTACH]
      NOTE:
      Hi teckat,
      I'm Massimo, a new user from Italy, I've just read your post and it applies to my problem. I own an ir-1022A bricked with a "STANDBY DOWNLOAD" message on the display, I suppose that I need to re-flash the firmware using the CANON USER SERVICE TOOL but I can't find it anywhere. Could you please tell me where can I donwload it? thanks
      • teckat
        • 16083
        B & W iR1022A is a Euro model/
        u can't use Color iRC1022 Firmware in it.
        don't know what USA firmware will work in it ?
        /is part of the Printers Firmware for models that use/need UST to flash it's firmware.
        • amg76
          Hello,
          I'm not a technician so I'm quite lost on the argument, I thought that the hardware was the same so probably the IRC 1022 firmware still works.
          • teckat
            • 16083
            Originally posted by amg76
            Hello,
            one is a COLOR Product =iRC1022
            other is iR1022 Black & White
            • zoraldinho
              teacher-guide-expert-guru
              • Mar 2008
              • 5007
              IR C1022 is not European model.
              IRC 1024
              IRC 1028
              Also we have Mercedes,BMW,Audi,Ferrari,Bugatti,Lamborghini..... .dancing-guy-smiley-emoticon.gif
              • teckat
                • 16083
                IRC 1021 [ATTACH=CONFIG]19890[/ATTACH]
                IRC 1024
                IRC 1028
                Also we have Mercedes,BMW,Audi,Ferrari,Bugatti,Lamborghini..... .[ATTACH=CONFIG]19891[/ATTACH]
                I know that/
                I was telling poster that iR1022 is a Euro
                don't know what firmware is used in it ?
                • Brutus279
                  • bipc
                    • Sep 2009
                    • 194
                    Hey Massimo and Brutus, if you need the firmware and the sst PM me your email languageto be in the machines and correct models, since you use euro versions i can help you guys with it, glad to help out
                    Life is a learning continuum...
                    • Cs12345
                      • Feb 2023
                      • 1
                      Necesito el finware porfa
