ir4570
  • akm
    • Sep 2012
    • 155
    [Error Code] ir4570
    Dear copytech team,
    i face a problem with the copierir 4570 that the screen of network scanner not appear what can i ndo to make it appear
    akm
  • charm5496
    • 2387
    Re: ir4570
    are you saying that there is not a tab at the top of the control panel for scan or for send?
    • akm
      • Sep 2012
      • 155
      Re: ir4570
      no sir , the problem that there is not a tab for a scan while i can make network print and the control panel have a tab for send
      • teckat
        • 16083
        Re: ir4570
        Enter Service Mode > Level 2 > Copier > Option > Body >< UI-RSCAN>
        Set UI-RSCAN to "1" to ENABLE the SCAN tab
        Level 2 setting. After you select *28*, press *2, to get into Level 2
        U mean the Online / Offline tabs are greyed out and can't be selected.
